Results 1 to 6 of 6
Thread: Feed Rate on Router with Big Bit
    Trinity County - 160 miles north of San Francisco. Redwood forest.
    159
    Question Feed Rate on Router with Big Bit
    I've got that "burnt popcorn' smell in my shop. I was cutting rather large (15/16ths) sliding dovetails in Douglas Fir 2x6's.
    Because of the hardness of the wood and the size of the bit, I was feeding it fairly slowly. The bit is a brand new HSS tool. How does one gauge feeding speed with a routeer?
    Gary Curtis
    Northern Calif.
    Steve Clardy Guest
    Feed as much as the motor will allow.
    Now. That wide of a cut, I would take a straight bit and cut most of the center out first. Or take your tablesaw and make 4-5 passes to remove the center of the cut.
    That will ease the burden of the router motor
    159
    Router Feed Rate
    I did in fact run a 1/2 straight bit first to cut a channel for the much bigger dovetail bit.
    I'll go into the shop right now and speed up process.
    Gary
    15,815
    Yeah, what Steve said.
    Often burning is because you are going too slow.
    Heathrow, FL
    91
    I agree with the others. Large bits to me are 2" large diameter and bigger. Your bit should be OK at higher speeds if not full speed.
    Could it be the HSS is dull already? I've never used one so can't say how long they last.
    Brian
    a bit is being fed correctly when you get light fluffy shavings.....if you`re getting dust or burning the bit is either dull or being fed to slowly or both...tod
  1. A day rate....?
    Last Post: 02-05-2016, 02:15 AM
  2. Exchange rate.
    By Bart Leetch in forum Off Topic Discussion
    Last Post: 02-01-2016, 12:52 AM
  3. Priority Mail Flat Rate - Any weight is sometimes less than I thought
    By Pete Simmons in forum Off Topic Discussion
    Last Post: 04-18-2015, 04:34 AM
  4. Get your heart rate up!
    Last Post: 05-13-2012, 10:20 PM
  5. What's your success rate?
    By Sandy Navas in forum General Woodturning Q&A
    Last Post: 03-26-2007, 06:38 AM
