Results 1 to 5 of 5
Thread: Make a Bed Extension for Jet 1642 Possible?
    Jun 2012
    Laurinburg NC
    316
    Has anyone ever made a bed extension for their lathe? I have a Jet 1642 and only need it to be longer once in a while when I set up to bore long flute blanks. I know it would need to be beefy enough to support my boring box and tailstock. I have been doing ok w/o an extension but it would be nice to have one.
    5,319
    Quote Originally Posted by Mike Turner View Post
    I'm not familiar with the 1642, but wonder if the extension for a mini (10-20?) or the midi (12-24?) would fit, or could be adapted.
    Dec 2008
    Portland, Oregon
    1,898
    Not sure if any of these willl work but check them out HERE
    Jesus was a Woodworker
    4,698
    http://www.amazon.com/Jet-708346-20-.../dp/B0009H58VA is the commercial variant.
    Folks have however made a variety of lathe extensions, doesn't look exceedingly hard although may be a bit fussy to get it lined up just right. If you google for "homemade lathe bed extension" or "diy lathe bed extension" you will see all manner of contraptions of varying levels of quality and durability.
    http://www.docgreenwoodturner.com/latheext.html looks alright (the 1642 and 3520 are similar enough that the idea translates easily) although I'd probably have gone heavier on the ways if I could have.
    http://www.ncwoodworker.net/forums/s...ead.php?t=8616 looks reasonable for a short one, if you could add a little more cross support on the ends of the ways it might be better, especially if you made it any longer.
    Feb 2013
    Clyce, Texas
    186
    I'm not sure how much extra length you need, but JT Turning Tools makes an attachment specifically for the 1642 that allows you to slide the tail stock off the bed and swing it down and out of your way: http://jtturningtools.com/tailstockmanager . It's the same length as the tailstock and stressed to hold the tailstock. You might contact them and see if it would also function as a short bed extender.
    Steve
  1. jet 1642 bearings
    By Larry Matchett in forum General Woodturning Q&A
    Last Post: 04-08-2014, 03:09 AM
  2. Buy Spare Belt for Jet 1642
    By Mike Turner in forum General Woodturning Q&A
    Last Post: 10-26-2013, 01:27 PM
  3. Make a Hook Tool - Easy to Make
    Last Post: 10-03-2009, 07:44 PM
  4. jet 1642 lathes
    By Clark O'Neill in forum Hot Deals
    Last Post: 11-28-2007, 07:21 PM
  5. Trying to make some saws...(did make a couple backs)
    By Alan DuBoff in forum Neander Tool Questions and Show & Tell
    Last Post: 07-20-2007, 06:41 PM
