Results 1 to 10 of 23
Thread: Lining Up Holes on Flute !
    Jun 2012
    Laurinburg NC
    321
    I make flutes. I turn my tubes and then I have to locate 6 holes on the flute body. I have been eyeballing this so far. I do my measuring and place the holes where they need to be but then you can sometimes be off on the tube a little. I have learned to start small so I can move it a lil if need be. But I have wondered if maybe I should get a cross slide vise where I could move the flute on the x-y axis sort of. I want to be more accurate on this step but not be over kill either.....And then if you look at the array of cross slide vises out there you wonder what is good and what isnt...I would love to try one for
    about $100 but I wonder how accurate those are?
    North West Indiana
    6,099
    Does your lathe have an index on it? If so, that could solve your problem.
    Jon
    4,701
    I have a $45 special from HF. Useful for some things, but I'm not convinced that it's the answer to you're problem here. I'm sure higher end ones are better, this one has a solid 1/4"+ of fun out so there is a lot of fiddling to get things lined up. The big problem I see even with a good one is that you still have some fiddly bits to get the piece centered on it unless you diameter is really really consistent.
    I think Jonathans suggestion may be better if you made a jig that ran in the ways of you're lathe with a drill on it, it might be easier to line up on the middle of the piece consistently. I assume you have some sort of template for the hole spacing?
    Cheaper and simpler would be a self centering V block that just rides on a fence on your DP table.
    S E Washington State
    3,777
    I could see how drilling on the lathe, with a jig would be a way of getting the holes centered down the flute but I don't understand how indexing on the lathe would fit in.
    "We the People ......"
    3,134
    [QUOTE=Paul Douglass;388576]I could see how drilling on the lathe, with a jig would be a way of getting the holes centered down the flute but I don't understand how indexing on the lathe would fit in.[/Q
    Paul & Mike
    How would it work to use the lathe index system & make a system where the main frame is clamped to the lathe bed & over the flute & the sliding part sets on top & down over the sides of it with a bushing to drill down through & on the side in-between the fixed part & the movable top part there would be the bullet part from a bullet latch & detents in the fixed part to preset the hole spacing?
    North West Indiana
    6,099
    Quote Originally Posted by Paul Douglass View Post
    I was just thinking with indexing you can lock it in place so with a jig you could drill a straight line of holes.
    Jon
    Jun 2012
    Laurinburg NC
    321
    The idea on having a drillpress that rode on a jig that ran in the ways of the lathe would work. And use the indexing system.
    I might go with the simpler idea for now.
    Ryan how do you make the V block self centering?
    3,777
    Quote Originally Posted by Jonathan Shively View Post
    Ahhh I see. Thank you.
    Dec 2012
    Bedford, NH
    1,683
    I don't know what the dia. of your turning is, but could you make a drill jig from PVC pipe that fits snug, or close to your turning? Or, if not perhaps you could bore the ID of some PVC pipe, or suitable material, that suit different size turnings. Once turned, you could drill the holes in the PVC pipe using a V-Block to centralize the pipe & set the hole spacings. Then you would have however many drill jigs available for future applications.
    Thoughts entering one's mind need not exit one's mouth!
    As I age my memory fades .... and that's a load off my mind!
    "We Live In The Land Of The Free, Only Because Of The Brave"
    “The problems we face today are there because the people who work for a living are outnumbered by those who vote for a living."
    Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
    11,833
    I have a low end xy vice from Grizzly. It meets my needs but I would not reccomend for anything precise or repeatable.
    Assuming you bore before turning, how about drilling small diameter pilot holes in the square stock before turning? Just a thought.
  1. MDF and dog holes?
    By Ken Cook in forum General Woodworking Q&A
    Last Post: 12-05-2014, 09:26 PM
  2. How to Drill Accurate Holes in a Cylinder or Flute ??????
    By Mike Turner in forum Jigs and Fixtures
    Last Post: 10-31-2012, 04:32 AM
  3. is it a Silver lining???
    Last Post: 09-27-2010, 01:41 PM
  4. Two more bowl gouge flute profiles
    By Gordon Seto in forum Turning Tool Questions and Show & Tell
    Last Post: 06-18-2008, 04:42 PM
  5. Box Felt Lining
    By Bob Wiggins in forum General Woodworking Q&A
    Last Post: 01-13-2008, 01:18 PM
