Results 1 to 10 of 19
Thread: Plan or Procedure for Building a Wooden Wall Switch Face Plate
    Apr 2013
    Staint John's, FL (near JAX)
    7
    Hi Folks,
    I have some spare wood left over from a project that would make really nice wooden wall switch face plates.
    I am having trouble getting started ..
    Has anyone made one of these ?
    I have searched the internet and could not find a plan.
    Thanks in advance.
    -Fred
    Fred J. Stellabotte
    Newbie Woodworker
    Jacksonville, Florida
    United States
    __________________________________________________ __________________________
    "The generous will prosper;
    those who refresh others will themselves be refreshed." - Proverbs 11:25
    Yorktown, Virginia
    5,015
    Hi Fred...not much help for you, having never made one, but if I had to make some I would go to Lowe's or Home Depot and take a look at their wooden switch plates to see what the back looked like and take it from there. My switches are rocker types, so the hole is large and rectangular. I'd probably make a router template of some kind to make more than a few and chisel the corners square, or print out a pattern, paste it on the wood and cut it out with a jig saw. Lots of ways to do it.
    SE Minnesota
    2,526
    I made a couple of them a few years ago. A friend wanted them in a different wood species than the choices available. I bought some cheap wooden one to use as a pattern and to scavenge for the metal plates they glue on the inside. I made them on the Router Boss so I didn't need to make a template but a template or two would be a good way to go. How many plates are you planning to make?
    Apr 2013
    7
    Hi Dave,
    I would like to make one or two every time I have some nice wood leftover. I have some really nice wood leftover from projects, small lengths. I can't throw them out, but the lengths are small. That is how I got the face plate idea.
    I think I understand how to use a trim router bit with a template, but I was wondering how to carve out the backside, and is a metal back needed.
    It would be nice to come up with a way to make them quickly. then I could give them away to family, friends and our Church which has fund raiser sales.
    Fred
    Fred J. Stellabotte
    Newbie Woodworker
    United States
    Yorktown, Virginia
    5,015
    Quote Originally Posted by Fred Stellabotte View Post
    ....It would be nice to come up with a way to make them quickly... Fred
    CNC...your next big tool purchase
    SE Minnesota
    2,526
    Fred, I have a template idea for a trim router in my head. Maybe I can make a sketch to show you.
    The metal plate will add a lot of strength--there isn't much when you get the plate as thin as it must be. If you tighten the screws down to secure the plate to a switch, it would likely split. There may also be electrical codes that require it. I know that we had to add extensions to the electrical boxes in our finished basement where the birch car siding was installed. The electrician had installed them for sheet rock not wood. It would be worth checking anyway.
    SE Minnesota
    2,526
    See if this makes sense for you.
    Basically you would have a base to hold the plate which is cut to size. Then a template goes over it to guide a router bit with a bearing on it. Make a different template for each cut but make them so you can swap them quickly. You'll probably also need to make a recess on the front of the plate around the switch bat or it won't stick out enough to be used easily.
    13,361
    Dave, you should write that up and send it in to the wood working mags. That's a great idea!
    SE Minnesota
    2,526
    thanks, Brent. I suppose now that I've made it public, it is too late.
    4,552
    We wont tell a soul Dave ( in my best Klinger voice I no NOTHING)
    A Turn N Time
    Frog Pond Guitars
  1. New Drive-Face Plate - New Toy update
    Last Post: 12-19-2010, 02:03 PM
  2. 800$ Wooden Plate from Brooks Brothers.
    By Brent Dowell in forum General Woodturning Q&A
    Last Post: 11-08-2009, 03:56 AM
  3. chuck plate/face plate
    Last Post: 10-27-2009, 05:17 PM
  4. A Plate around the face
    By Robert Schaubhut in forum Jigs and Fixtures
    Last Post: 05-19-2007, 03:34 AM
  5. Building a wall........
    By Stuart Ablett in forum Carpentry and Construction
    Last Post: 05-02-2007, 12:17 PM
Tags for this Thread
