Results 1 to 10 of 10
Thread: Pair of Cherry Picture Frames
    London, Ontario
    3,383
    A tale of two pictures...
    These two paintings were made by a distant relative in Western Australia in the early 70s. I've had one for a few years, and recently obtained another. I decided to make some matching frames for these two paintings. I don't have any exotic Australian wood to go with the subject matter, so I had to "settle" for working with native black cherry lumber.
    I tend to prefer fairly simple picture frames. I don't go for heavily ornamented or gilded or carved or... or anything like that.
    I used Sketchup to come up with a design that I liked for these frames. One neat feature of Sketchup is the ability to import pictures, so I snapped a photo of one of the paintings and imported that into Sketchup, and used that when doodling designs. (I doodled a whole bunch of different options before settling on this fairly conventional design.)
    This is an end-view of one of the frame pieces, as designed, with all the measurements noted. If you want to duplicate this yourself, all you need is a tablesaw and a router + router table.
    Step One: plough a pair of dados in the frame stock on the table saw.
    (Yeah, I'm skipping a bunch of steps here. I just was going to present a fairly high-level look at this project. I first sorted through my stock, selected the boards I wanted, made sure I had enough, cut some boards down to workable sizes, jointed and planed to 3/4-7/8" thickness and ripped to 2" width. Actually made a 3rd frame at the same time, out of 3" stock, but I'm not showing that...)
    Step two: Take a series of cuts with the roundover bit to round the outside of the frames.
    Step three: Take another series of cuts with a cove bit to cut out the inside edge of the frames.
    Step four is not shown. Depending on the size of what you'r framing, rip a rabbet along the bottom/inside edge of the frames to receive your painting.
    Step five is to cut the pieces to size. I used a 45-degree mitering sled to cut these on my tablesaw. Mine is based on one of Steve Ramsay's (woodworking for mere mortals) videos and plans, but there is nothing that unique about it. Works awesome to make tight joints.
    I don't have a strap or band clamp, so clamping 45-degree angles is tricky. I tried just using my parallel clamps and "Bad Things" happened... ('nuff said about that!)
    Of course there are many ways to approach a problem. I own a Dowelmax dowelling jig, and that proved to be a fairly quick solution for my situation. I used the dowel jig to put one 1/4" dowel hole in the face of each joint. I don't need them for the strength, just for the alignment. Here is one frame being test-fitted.
    I applied some glue inside each dowel hole, slip in a fluted dowel. (I use compressed/fluted dowels which expand when in contact with water based glue.) Then apply glue to the face of the miter joints and close up the joints. The dowels force the joints to stay aligned. The clamps can then be tightened just a bit to hold things tight and square as the glue dries.
    For finishing I wiped on one coat of sealcoat shellac, followed by two coats of waterbased varathane. I was tempted to just use some spray lacquer, which would be quicker and look much the same, but we are having a -15c cold snap right now, and it is far too cold in our garage to spray lacquer.
    That is about the end of that. All that remains is to hang the paintings in their new home. And as a bonus, I have some frame piece already prepared in storage for future framing needs.
    (more on the design side on my website, but this is the most of it)
    Just beautiful. Those set off the artwork much better. You do them proud.
    Independence, Kentucky
    1,355
    Nicely done Art, Just the right amount of detail
    17,472
    looks good art, what is that a picture of? some form of cactus?
    Nov 2010
    Arkadelphia, Arkansas
    139
    I like them Art! Excellent design and craftsmanship!
    Norm
    I have a mind like a steel trap....
    ....rusty and illegal in 29 states.
    Thomasville, GA
    5,994
    Beautiful work, Art! Nice tutorial, also.
    Bill Arnold
    30,017
    Well done, Art, and thanks for the details about the process.
    Catalunya
    4,632
    Great frames Art, I'm like you I prefer simple ones that do not steal the attention from the picture.
    Best regards,
    Toni
    London, Ontario
    3,383
    Strangely enough, given how long we've owned the paintings, I have no idea.
    Jun 2007
    4,944
    Dang it Glenn. Way back when you were age 16 I told you to get a haircut. See what happens when you don't listen to your dear old dad!
    Art, you have a good feel for art frames. What you did suits the paintings.
    Enjoy,
    JimB
    VOTING MEMBER
  1. picture frames
    Last Post: 09-27-2014, 05:19 AM
  2. Picture Frames for the 4th
    By glenn bradley in forum Flatwork Project Showcase
    Last Post: 07-02-2010, 07:08 AM
  3. flame birch picture frames
    Last Post: 04-13-2009, 02:19 AM
  4. Picture frames - Amatorski methods
    By Niki Avrahami in forum Flatwork Project Showcase
    Last Post: 03-18-2008, 09:14 PM
  5. Picture Frames-Profitable?
    By Travis Johnson in forum General Woodworking Q&A
    Last Post: 10-28-2007, 05:50 AM
