Results 1 to 7 of 7
Thread: Redwood Burl
    Apr 2009
    Red Deer, Alberta, Canada
    1,083
    Redwood Burl
    Sanded to 400x, buffed with extra fine steel wool, burnished with turned wood shavings, cleaned with tack cloth, and applied 6 coats of Satin MINWAX WBOM Polyurethane using my "Dipping Method".
    Dressed with a Black Titanium/Platinum Hybrid Double Twist Cigar.
    Les
    Innovation is the process that renews something that already exists and not, as is commonly assumed, the introduction of something new.
    Very pretty, Les. I've always been fond of redwood burl. Was the blank stabilized? I've turned redwood burl both stabilized and not, and I much prefer the stabilized stuff.
    Aug 2008
    Reno, Nv
    3,632
    Sure am glad you went with satin...great chunk of wood!!
    I'm with Vaughn. Since I can stabilize at will...all burls and punkies get the treatment.
    Apr 2009
    1,083
    Vaughn,
    So far I have not been stabilizing the Redwood Burl I have.
    Les
    I think all the redwood burl pens I've turned have been stabilized, but I've turned some bigger pieces of unstabilized redwood (burl and otherwise). For me, it's pretty easy to over-sand the unstabilized stuff because of the different densities between the growth rings.
    10,604
    Beautiful job as usual Les
    I was given what I was told was redwood burl. Certainly looked the same as your wood. The piece I had turned to dust as I turned it. No curls just dust.
    Jun 2007
    4,944
    Bob, You sure that wasn't my brain you got a hold of instead of redwood?
    Les, that is a beautiful pen.
    Enjoy,
    JimB
    VOTING MEMBER
  1. Redwood Burl
    Last Post: 01-24-2014, 06:08 PM
  2. Redwood HF
    Last Post: 06-11-2011, 04:11 PM
  3. Redwood box
    Last Post: 10-29-2008, 08:01 AM
  4. Natural Edge Redwood Burl Vase
    Last Post: 10-05-2008, 04:24 PM
  5. Replies: 12
    Last Post: 04-07-2008, 04:33 PM
