Results 1 to 6 of 6
Thread: Stairway to hardwood heaven
    My wife had a little accident involving a can of red paint, her foot, and the carpet on the lower section of our staircase. Let it suffice to say that the carpet needed to be replaced. We had family coming over yesterday for Easter, so it needed to be replace fast.
    We had found a box of Mannington engineered hardwood that had been used in the parlor before we bought the house. If you have never seen engineered hardwood, it is nothing more than a 3" strip of 3/8" plywood that has a veneer of hardwood (in this case oak) on top. I really liked the floor in the parlor because the wood strips had chamfered edges that really made the individual boards stand out. So I decided to use that box for the stairs, however there wasn't enough, so I went and got a couple more. The capping for the edge of the tread was quite expensive though ($300), so I decided to make my own for about half the price. If this was anywhere but California it would have been a quarter of the cost, but oh well.
    I went and got some 8/4 FAS oak for about $150. I cut it into 1-3/4" square strips. I used my router table to put a bulnose on the top front edge and an ogee on the bottom front edge. Then I used my table saw to cut a 3/4" wide rabbet in the back to accomodate the plywood subfloor on the treads. I used Minwax Golden oak stain and water soluble high gloss polyurethane to approximately match the flooring. I say approximately because the flooring has subtly differing shades to per each board, which is nice. So the small difference in the hardwood capping should not be as noticable. I used some sanded plywood on the front riser, which my wife painted to match the trim. The end result turned out quite well in my opinion. I finshed putting on the last coat of poly about two hours before the guests were supposed to arrive. So all in all, I would say it was a success. Let me know what you think.
    Attached Thumbnails Attached Thumbnails 4707 (8).jpg   4707 (9).jpg   4707 (10).jpg   4707 (11).jpg   4707 (12).jpg
    Last edited by Rob McCune; 04-09-2007 at 05:09 AM. Reason: Added pic of it in its original state.
    29,864
    Nice job. Talk about getting done just in the nick of time.
    Rob
    Great job! And now that the company is gone, are you going to continue up the stairway? Where will you stop?
    Jay
    Charlotte, NC
    1,487
    Nice job and quick thinking!
    Steve Clardy Guest
    Good job
    1,289
    Very, Very nice job Rob.
    DT
  1. My Shop (Ok, it is really heaven)
    By Neil Hoffman in forum Shop Tours
    Last Post: 03-12-2014, 05:50 AM
  2. Stairway to the Attic
    By Tom Hoffman in forum Shop Tours
    Last Post: 06-21-2010, 01:39 PM
  3. I built some cabinets that would not fit down the stairway
    Last Post: 02-23-2010, 02:17 PM
  4. Chocolate heaven
    Last Post: 12-18-2008, 04:16 PM
  5. Tool Heaven
    By Rob Bodenschatz in forum General Woodworking Q&A
    Last Post: 09-05-2007, 12:18 PM
