Results 1 to 10 of 23
Thread: Dado Set Cleaning Tips
    Jul 2007
    DSM, IA
    5,719
    My dad gave me his old Delta dado set last time I was over. I had told him I was looking to buy one with some xmas money I received. He told me he had 2 and never really uses either so I could have one. He prefaced it with, "It's dirty, probably not sharp, but should all be there." I was happy to have it! Couple nights ago I went out in the cold shop to try and clean it up. I was armed with WD40, a wire brush and a scrub pad. The WD40 worked ok until the tip froze up. I went back into the warm house after that.
    So long winded story made short...what do you guys use to clean up and old blade like this?
    My Website
    5,167
    I spray on router bit cleaner on both sides. Let sit for two or three minutes. Rinse off and dry thoroughly. May need soft brush to get stuff out of tight places. Others have suggested that Simple Green works as well. Same procedure, though Simple Green may need a longer soak. I use the cover of a plastic 5 gallon bucket as a container. Just spray liberally, flip, and repeat.
    13,437
    Yeah, I don't see any carbide on those, so just some simple green should do the trick, though I'm not sure what to use for the rust stains.
    10,600
    http://familywoodworking.org/forums/...hlight=lestoil
    I use lestoil regularly. I haven't found anything better yet.
    Jul 2007
    DSM, IA
    5,719
    Thanks for the tips, very much appreciated!
    My Website
    Dec 2012
    Bedford, NH
    1,683
    Also use Lestoil as this was recommended here on FWW. It works well on carbide toothed blades as well. I tried Simple Green & it worked well too, but was advised that it had negative affects on carbide (???). So, rather than chance a problem, I went back to Lestoil. I use the lid from a 5 gal bucket (suggested by Bob) to place the saw blade in & rest in the Lestoil for a few minutes. Then rinse in hot water with a soft brush. I usually do several blades at a time (one at a time to avoid damage to the carbide teeth) reusing the same Lestoil in the lid. Works well. Try it, you'll like it!
    Thoughts entering one's mind need not exit one's mouth!
    As I age my memory fades .... and that's a load off my mind!
    "We Live In The Land Of The Free, Only Because Of The Brave"
    “The problems we face today are there because the people who work for a living are outnumbered by those who vote for a living."
    Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
    Nov 2010
    Arkadelphia, Arkansas
    139
    +1 on Lestoil. One of the great tips I've learned here.
    Norm
    I have a mind like a steel trap....
    ....rusty and illegal in 29 states.
    13,437
    I guess I'll stop and get some Lestoil, I didn't realize that it was a household cleaner, never heard of it before.
    Sep 2011
    Newnan, GA
    31
    Don't use anything. Use the Christmas money and go buy a nice carbide tipped dado set. Just my 2 cents.
    "When the horse is dead....Get Off!"
    Austin, Texas
    1,448
    The original Simple Green could attack metal (the carbide brazing), and was not allowed for anything on aircraft, since a spill could get into the airframe. The second version was called "Simple Green Extreme" which, despite the name, was milder, and safe on metals - saw blades and aircraft. The extreme version went away several years ago, and just has the "Simple Green" name, but it is not the original over-aggressive version.
    I use Simple Green as our primary household cleaner (dilute in spray bottles, etc.). It is one of the options I use to clean blades and router bits, although in a higher concentration than the spray bottle that we use all over the house.
    Charlie Plesums, Austin Texas
  1. Cleaning the Pot...
    By Art Mulder in forum Off Topic Discussion
    Last Post: 10-30-2013, 02:06 PM
  2. What do you use for every day cleaning?
    By Rennie Heuer in forum Finishing School
    Last Post: 10-24-2012, 03:01 PM
  3. Been Cleaning
    By Chuck Thoits in forum Shop Tours
    Last Post: 01-19-2010, 07:13 PM
  4. Cleaning, cleaning, thinning out.....
    By Douglas Jones in forum Old Ads
    Last Post: 06-24-2008, 09:59 PM
  5. Clean Air... ***Up and cleaning***
    By Greg Cook in forum New Tools
    Last Post: 03-13-2008, 09:04 AM
