Results 1 to 10 of 16
Thread: Finish for Purpleheart?
    Jan 2014
    Providence Forge, VA
    51
    My next project will be making a jewelry box from Purpleheart for my granddaughter. I previously have only used Purpleheart for a cutting board, so I am looking for some ideas on what to use for a finish on the box.
    Earl
    Aug 2008
    Reno, Nv
    3,632
    Hey Earl!! I like a little oil type finish, currently Formbey's Tung Oil finish, to soak in, then a lacquer over the top. Spray stuff like Zinsser has worked well for me with a little wet sanding in between
    Quote Originally Posted by Jim Burr View Post
    Be sure the oil finish is fully cured before hitting it with lacquer, though.
    Aug 2008
    Reno, Nv
    3,632
    Oooo...good point! Any undercoat needs to be fully cured before moving up and out!! There is a cheese and cracker platter that is almost ready for WOP, but the Formby's needs another day. Thanks brutha!!
    Especially important with a true oil finish like BLO or tung oil. In those cases, I'd give it a couple weeks to cure. Formby's should be OK after a few days. (Check to see if it still smells like finish. If it smells, it's not fully cured.)
    Jan 2014
    51
    Thanks for the tips. I want something that will not darken the wood any more then it already is. I know Purpleheart will not stay purple but I would like it to be as good as it can be, when I give it to her. I was wondering how just using a sealer and a water based wipe on poly would work.
    Earl
    Quote Originally Posted by Earl Rumans View Post
    Earl, I think you're on the right track with the water based finish. I'd avoid any oils if you want to keep the color lighter. Out of curiosity, why use the sealer? Water based poly should work fine on raw wood.
    17,477
    another vote to skip sealer and i have seen some of the water base products hold purple heart color for a long time.. the target coatings seem to be the one to go to for that..
    Jan 2014
    51
    OK. I think that's what I am going to try. Just use the water based poly without using any sealer. I have used the Target products before and I like them, so that's probably what I will use. Would you use a foam brush or just a cotton towel for application. I am not that familiar with water based poly, can I build up the number of coats and then sand for a rubbed like finish?
    Earl
    17,477
    my vote is spray it if you have the equipment to do so.
  1. re-purpling purpleheart
    By Dan Noren in forum General Woodworking Q&A
    Last Post: 07-20-2010, 01:03 PM
  2. Purpleheart
    By Peter Lyon in forum General Woodworking Q&A
    Last Post: 12-21-2009, 01:29 AM
  3. PurpleHeart Jolly Roger
    By Kevin Vernon in forum Flatwork Project Showcase
    Last Post: 06-09-2008, 12:29 PM
  4. clear finish on Purpleheart?
    By Kevin Vernon in forum Finishing School
    Last Post: 05-21-2008, 08:23 PM
  5. Purpleheart & Maple
    By Ed Nelson in forum Lathe Project Showcase
    Last Post: 04-09-2007, 01:17 PM
