Results 1 to 6 of 6
Thread: Vacuum bag material thickness?
    Honolulu, Hawaii
    1,103
    Aloha peoples. I am thinking of making a vacuum bag for some laminating I want to do. I will probably just use sheet polyethelene material, but don't want to go too thick or too thin. Your choices? It will probably be about 4' x 7' max.
    Mahalo to all.
    Ah,,,to live in Paradise!
    Registered voting member
    17,474
    check out joe woodworker for his bag thickness.
    5,322
    Mine are 20 mil (0.020") thick vinyl.
    Joe Woodworker sells both 20 and 30 mil material, in vinyl and PVC, and the proper glue for sealing it.
    13,451
    Marc Spagnuolo (The Wood Whisperer) did an episode a while back. I believe he did both types (vinyl and pvc) and covered some tips for each. He also used Joe Woodworker also.
    http://www.thewoodwhisperer.com/vide...essing-matter/
    Honolulu, Hawaii
    1,103
    Thanks guys for the info. I will check them out. Aloha.
    Thomasville, GA
    5,998
    I used some vinyl material from a fabric shop for many years. It is about 10mil and worked just fine, but last year I replaced it with 20mil vinyl from Joe.
    Going way back to the point I first got a vacuum pump, we had an extra vinyl shower curtain laying around at home, so I tested with it. It worked quite well for some bentwood pieces I needed for a project. Dirt cheap, too!
    Bill Arnold
  1. Need advice on a thickness planer
    By Ninh Shepherd in forum New Tools
    Last Post: 01-30-2014, 02:58 PM
  2. Setting Laser for thickness
    Last Post: 11-28-2010, 04:29 AM
  3. Panel Thickness on Cab Doors
    By gary curtis in forum General Woodworking Q&A
    Last Post: 09-11-2007, 09:29 PM
  4. Wood Thickness
    By Rob Bodenschatz in forum General Woodworking Q&A
    Last Post: 06-28-2007, 11:42 PM
  5. Thickness sander vs. planer?
    By Mark Rios in forum General Woodworking Q&A
    Last Post: 11-03-2006, 08:15 PM
