Results 1 to 4 of 4
Thread: Sketchup hot keys
    Wake Forest, NC
    292
    Sketchup hot keys
    In sketchup 5.0 I had a short cut key to erase all construction lines by pressing the letter E. How do I set this up in the new version 6.0?
    Sacramento, CA
    1,367
    Oh shoot, i know this ... but i'm at work and don't have it installed ... for me, it's two steps, though. There's a menu item, something like Edit -> Delete Construction Geometry... or something like that, so i hit alt+e then alt+d ... it's the only way i've found.
    Jason Beam
    Sacramento, CA
    SE Minnesota
    2,550
    Travis, sorry, I was off working on a new SU model.
    Go to Window>Preferences>Shortcuts. Select Edit/Delete Guides. In the little window to the right type your desired shorcut. I use E. Hit the + button and it should appear in the lower window as assigned. Clcik OK.
    Wake Forest, NC
    292
    Ahhh... Thanks, they changed the name of it.
  1. Need sketchup help please
    By Bob Gibson in forum Designs, Plans and Sketches
    Last Post: 10-14-2015, 10:26 AM
  2. Sketchup to DXF
    By Darren Wright in forum Designs, Plans and Sketches
    Last Post: 11-24-2010, 07:24 PM
  3. FORD Keys gripe
    By Kirk Constable in forum Off Topic Discussion
    Last Post: 02-18-2008, 12:08 PM
  4. DXF to SketchUp
    Last Post: 06-25-2007, 11:07 PM
  5. An Example from SKETCHUP 6
    Last Post: 01-13-2007, 12:32 AM
