Results 1 to 10 of 17
Thread: Snow Loads Question
    12,260
    Snow Loads Question
    Had another dump of the white stuff last night here.
    So i have a question that has crossed my boy scout mind.
    Having observed the extensive damage the ice storm caused to enormous trees here, just before Xmas , and although we had a little melt occur the last few days, it was not sufficient to do much melting.
    So we have a layer building on the roof which looks likes its set for the duration of winter.
    The layer is about 2 inches of snow followed by at min 1 inch of solid ice followed by what was before last night another 2 inches of snow.
    Now i guess that top layer of snow is at least another 2 inches thicker so its up to 4 inches. Now the most recent is not as compact as the prior stuff so I guess its not as heavy.
    But my question really is has anyone got an idea of what or how one determines when its necessary to do something to get rid of the load. Like what amount of snow is typically catered for in snow load calculations.
    I can see snow load calculations being different for different areas given historical and anticipated snow loads so I suppose its a bit like how long is a piece of string. But anyone have any kind of frame of reference.
    17,475
    LINK
    takes awhile to load.
    Dec 2012
    Bedford, NH
    1,683
    Rob, frankly there are too many unknown variables involved to directly answer your question: roof pitch; uniform vs. concentrated loading; depth & consistency of snow/ice; wind direction & speed, and maintenance. The construction on homes is controlled initially by the state & local building codes, and by the local building inspector, providing he/she is competent & inspects the construction at the specified construction milestones. I think you can get a good idea from the link Larry noted above, but I think the best person to answer your question would be your local building inspector, again providing he/she is competent.
    Thoughts entering one's mind need not exit one's mouth!
    As I age my memory fades .... and that's a load off my mind!
    "We Live In The Land Of The Free, Only Because Of The Brave"
    “The problems we face today are there because the people who work for a living are outnumbered by those who vote for a living."
    Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
    5,173
    You are renting, right? Landlord's problem. When you build your dream place, then it is worth thinking about. Or move south.
    12,260
    Re: Snow Loads Question
    Thanks Larry for the doc link, i can see how this question is how long is a piece of string.
    @Carol, yeah its Landlords issue but i dont wish to be under the roof when it goes or have to have my life put on hold while we recover our belongings.
    This is a very old place. Here is a picture of ice/snow on the garage which is really not in as good a shape as the house. My tools and machines are in there otherwise i would not care. What makes me concerned is simply the very basic issues i have had with the side door opening and closing so i get to see the movement.
    In addition the way the rafters meet the wallplate has them looking rather bent. But thats not new been like that since we moved in.
    Note this was before last nights dumping.
    sent from s4
    Dec 2012
    Bedford, NH
    1,683
    If the side door is telling you that there is some settling going on, and you are apparently concerned, then you, or your landlord, could throw up a few temporary posts & beams under the rafters that'll get you through the winter, until a more permanent fix is done.
    17,475
    show picture of the inside roof area, sounds like you dont have any collar ties.. as for the load you show, it appears to be around 8" total and mostly snow.. i wouldnt worry about that little bit but you can contact your land lord and give him the option and then you have done your part.
    Yorktown, Virginia
    5,020
    Quote Originally Posted by Al Launier View Post
    As Al said, some temporary supports should get you through the winter. Also look at the snow fall history for your area. If the roof has had major accumulations on it in the past, then it should hold up to lesser loads. If your roof structure is trussed, deflection may be a good indicator of when to put your temporary supports up. Rig a weighted no-stretch type line to a key rafter and measure deflection between the weight and the floor. That should tell if the trusses are deflecting and how much. If you can get to the ridge, you could try the same there.
    North West Indiana
    6,099
    If it were new construction I would be worried. I figure old construction (pre 1970's) saw and lived through the biggest snow storms so just do reasonable care.
    Jon
    Thomasville, GA
    5,998
    ... I can see snow load calculations being different for different areas ...
    Sho' ain't much of a problem down here, Rob!
    Bill Arnold
  1. Drifting Snow Question
    Last Post: 02-23-2013, 12:23 AM
  2. Woodmaster loads of potential
    Last Post: 01-28-2011, 09:40 PM
  3. A website with loads of neader tool tips
    By Rob Keeble in forum Neander Woodworking Q&A
    Last Post: 07-05-2010, 01:17 AM
  4. nd now for something completly different ;) warning loads of piccies
    By Karl Wissinger in forum Carpentry and Construction
    Last Post: 02-08-2010, 09:46 PM
  5. Got Snow?
    Last Post: 01-05-2008, 03:03 AM
