Results 1 to 4 of 4
Thread: How to Unload large machines
    The Heart of Dixie
    4,268
    I went to Birmingham this morning to look at the old saw. It has some issues but I went ahead and traded with the fellow but that is for another thread. People always panic about unloading the smaller saws and thought I would show one way to do it.
    First problem. Getting it in the door! I back to the Lab door and things don't look to good.
ID:	7021 Click image for larger version.
    Houston we have a problem! I pondered on this and knew I could lift it with the engine lift but it that wasn't going to help. It would still hit the house and then when I lowered it would be on the ground and no way to move it inside with the lift. Than I had an idea
ID:	7023 Click image for larger version.
    Look ma! It fits! Barely but it just fits. Now how did he do that?? Pretty simple actually.
    OK first hurdled crossed. Now lets unload this beast.
    Custom built boats and Kits
    The Heart of Dixie
    4,268
    UNLOADING
    Engine lifts are worth their weight in Gold! Rent one if you don't want to buy one!! Here is why. This casting probably weighs in at 900 lbs or better. You and buddies are not going to pick this one up and move it around.
    With the lift there it nothing to it. Did this by myself. Once I found the center line I could pick it up and roll it to the back of the trailer no problem.
    Turned it around and found it wanted to rest on top of he legs of the lift. Again, not a problem!
    Just took some scrap and placed them in between the legs and castings let it down a little at a time. Adjusted the wedges so speak as I slowly lowered it to the floor of the trailer.
    You end up with the casting on an angle so you just have to slowly finish lowering it and making sure that it stands upright. Which it did no problem.
    Then just move the lift to the shop floor and take it on off the trailer. All done in 10 minutes by myself. No sweating and straining and done safely too.
    It was a LOT harder unloading all the pieces such as the table and the wheels than it was to unload the frame. If you going to be moving much around these lifts are the ticket!
    17,516
    ole pro!
    i think ya dun thast b4 jeff not bad for a southern gentleman. have had few heavy lods to get off the trailer b4 myslef. and if things go as planned this summer i will have a hoist just for such things, drive in hook up lift off, drive out let down, roll to it final resting place
    Punta Gorda, Florida
    902
    You can include me in the group that thinks this is a great tool. I have the foldable version. I also have a beam in my garage and it is only bolted to the roof supports so I have to put some 4x4s under each end when I use it.
  1. Value of used machines?
    By Charlie Plesums in forum General Woodworking Q&A
    Last Post: 02-27-2015, 05:09 PM
  2. Replies: 16
    Last Post: 04-30-2012, 12:14 PM
  3. FYI on old machines
    By Bill Simpson in forum Old Iron
    Last Post: 07-27-2010, 07:11 AM
  4. better than the machines
    By Paul Hubbman in forum Neander Woodworking Q&A
    Last Post: 12-01-2008, 11:20 AM
  5. WW Machines and Metal
    By Travis Johnson in forum Designs, Plans and Sketches
    Last Post: 12-03-2006, 04:40 PM
