Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
Thread: Bucket Case Bandsaw
    The Heart of Dixie
    4,268
    Bucket Case Bandsaw
    Brought the American Wood Working Machines bandsaw home today. Meet the owner and looked at it but had some concerns. Decided I would be in it DIRT Cheap/You Suck price so what the heck. I can make money by parting it out. But I don't think the issues are that serious.
    We spent and hour looking at parts trying to decide what was what and where it went and what was missing. Finally realized that one of the shafts was missing. He dug around his basement some more and found it. Then we discovered another major part missing.
    He said it was at the parents. Called and just caught one of them walking out the door. He left and I tried to decide how the heck to load this. He came back shortly with the part and we continued to try to place all the part and look for missing parts.
    I finally decided everything appeared to be there minus the motor. He trashed the original! Made me want to cry. I will never be able to replace that! The lower blade guide is missing at least one piece and he thought he knew where it was but couldn't get back in his parents house where the saw was before he moved here. The lower guide looks like it was rigged and not factory so I wasn't to worried about that part. I can make or buy a guide that will work and you won't see it unless you look. Besides it will probably work better! The upper guide is there but missing one piece. Again, I can fab something there. Thats not a deal breaker.
    So we loaded her up in buckets. Loaded the castings and I brought her home. This is going to be a big project and will take some time since I have to fab some parts. I guess that is just part of dealing with 1920's machines. I know this is going to be a big project.
ID:	7031 Click image for larger version.
ID:	7032 Click image for larger version.
ID:	7033Click image for larger version.
    I think I may have to put this one together as-is while it's still fresh in my mind where some of this goes. Photograph it and then tear it down and start refinishing.
    Custom built boats and Kits
    Steve Clardy Guest
    So how does the weld look?
    2,784
    All I can say is WOW!!! Yeah, you have your work cut out for you, but that will be something when you get it finished. Looking forward to the progress reports and pictures. Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    The Heart of Dixie
    4,268
    Weld was OK Steve. But that trunnion has a problem. It appears that the dovetails are babbit! They were added to the casting for sure. Some softer metal and not Cast Iron for sure. When you crank the table one direction, even it it's rusted state it works fine. When you try to go the other way the table bracket binds. That's where my concern is. Was it welded crooked or something.
    After I go it home I think I found the problem. It has a worm gear setup and the shaft on the adjuster is loose in there. When you crank it the gear moves and appears to bind in the teeth. Will have to tear that part down to see better what is happing. May just mean boring it out and adding a bronze bushing or something like that.
    Steve Clardy Guest
    Hmmm. Shaft hole may be worn, letting the gear cock sideways, then binding.
    Babbit in the shaft hole?
    The Heart of Dixie
    4,268
    Quote Originally Posted by Jim O'Dell View Post
    All I can say is WOW!!! Yeah, you have your work cut out for you, .....
    This is nothing. Wait till you see what is coming. Talk about a project!
    Steve Clardy Guest
    So, soon you will have three piles of ol' iron to work on.
    That ought to keep you out of trouble
    15,815
    Geez Louise
    Yep, that will keep you out of the pubs for a while
    The Heart of Dixie
    4,268
    It ain't nothing but a big jig saw puzzle with some rust on it.
    Jeff
    The Heart of Dixie
    4,268
    Decided that I wanted to account for the part and pieces. So I started putting he saw together last night. Nothing it tight or anywhere near ready to run. But I now know where most everything goes. And figured out what is missing too.
    Kind of looks like a saw now. And helps to understand just how big this sucker is!
    Jeff
  1. one more off the bucket list
    By Chuck Ellis in forum Lathe Project Showcase
    Last Post: 03-31-2016, 02:52 AM
  2. What's on your bucket list?
    By John Daugherty in forum Off Topic Discussion
    Last Post: 12-02-2011, 10:05 PM
  3. The Ice Bucket
    By Dennis Kranz in forum Lathe Project Showcase
    Last Post: 09-16-2011, 07:51 AM
  4. 12 sided Bucket
    By Ron Roase in forum Flatwork Project Showcase
    Last Post: 07-01-2011, 05:57 PM
  5. Photo Bucket Virus
    By Jonathan Shively in forum Off Topic Discussion
    Last Post: 01-26-2009, 04:08 AM
