Results 1 to 10 of 21
Thread: Calling owners of MiniMax 16's
    Steve Clardy Guest
    I installed a 1/4" blade on the impressive bandsaw yesterday.
    I needed 1/4", so I could cut out some knee knockers for a kitchen island.
    The upper/rear roller is adjusted as far forward as it will go, lacking 3/8" of making contact with the rear of the blade.
    Lower guide is fine.
    Seems the front blade guard is in the way.
    I'm thinking of taking a cutoff saw and notching the blade guard.
    Or am I missing something here
    I needed to get these done, so I went ahead and eased into them [ 1 1/2" Oak blanks] and didn't have any problems.
    Albuquerque, New Mexico
    1,099
    Steve, there’s something screwy with your setup. As you can see, the guard should be well above the guides. Are you sure that it is assembled correctly?
    friend...if you have one."
    one."
    Steve Clardy Guest
    Bruce. It looks like its assembled right.
    It came assembled. No manual to reference to.
    Mine has 4 sections to the guard. 4 sections that collaspe into each other as the cutting heighth is raised up.
    Its all the way down now.
    The lower section is bolted to the shaft that raises/lowers the cut heighth.
    Yours is different. Plastic lower section?
    1,099
    I think mine’s an earlier generation. You can see in this blurry pic how the tab from the 4-section guard attaches to the guide post, well above the guides. The plastic part is completely independent of the telescoping part. I don’t know what else to tell you but I think you should hold off on modifying it. Something’s not right on your machine.
    one."
    1,099
    I just took a quick look at the MM web site. Their pics also show the guard above the guides.
    one."
    Steve Clardy Guest
    Ok. Yours bolts on the same as mine.
    But I have a fifth section, which is steel, that is interfering with the roller.
    Apparently your lower section, plastic, is cut out for the roller?
    Central CA
    797
    Steve, I just went out to check mine and it is the same as yours. We have the same vintage as we received them just a few days/couple weeks apart IIRC.
    I haven't tried to put on a smaller blade yet but I had noticed that there would be a clearance issue when I did.
    Maybe Sam can chime in to tell us a fix. Can you call them and talk to him?
    It doesn't look like it would hurt anything to notch the guard, to me anyway.
    Thanks, Mark.
    Custom Bonehead.
    My diet is working good. I'm down to needing just one chair now.
    "Just think how stupid the average person is, and then realize that half of them are even stupider!" --George Carlin
    Tokiwadai, Japan
    2,882
    I would get MM involved before making any mods....something is either wrong, or something needs to be done differently. Better to start from the way it was received...rather than where you are after modifying it.
    My thoughts.
    track the blade in the center of the wheel instead of forward......
    15,815
    What about the set of the teeth on the blade?
  1. Minimax E16 Bandsaw
    By Jeff Hamilton Jr in forum Old Ads
    Last Post: 05-21-2010, 07:40 AM
  2. Anybody get the call from Minimax that I got this morning?
    By Mark Rios in forum General Woodworking Q&A
    Last Post: 04-03-2008, 07:46 PM
  3. a mini gloat as in Minimax.
    By Joe Mioux in forum New Tools
    Last Post: 08-02-2007, 12:34 AM
  4. Minimax FS31
    By Travis Porter in forum Old Iron
    Last Post: 02-03-2007, 06:17 PM
  5. minimax usa website
    By Chris Mire in forum General Woodworking Q&A
    Last Post: 11-11-2006, 12:08 AM
