Results 1 to 10 of 20
Thread: Oh, Gee Wizzzzzzzzzz
    S E Washington State
    3,777
    I started working on this new toy yesterday. Today I worked all day making the grill and attaching it to the hood. It took me 4 attempts to get the grill just like I wanted it. I attached it to the hood and the final step of this piece of the car was to round over the hood. This is what I did! Entirely stupid of me. I took too big of a bit with the router bit and I probably should have backed over the very front portion of the hood assembly because of the direction of the gain on the front piece. I don't know how to fix it other than cutting the grill section off and rebuilding it. I know wood filler would never match and would really show up, this won't be painted. Anyone got any suggestions other than replacing it? I'm really bummed!!!!!!!!!
    "We the People ......"
    Dec 2012
    Bedford, NH
    1,683
    Well, first of all Paull Gee Wizzzzzzzzzzzzz won't cut it. You really need to vent to get your stress level down!
    When I screw up (frequently & usually major blunders), I find it best to walk away for a day (minimum) to cool off & clear the mind. During that time a seed starts to grow and before you know it, a plan comes through.
    Stay cool, it'll come.
    PS I really like the models you're working on. Starting to perk my interest. May start searching for plans online.
    Thoughts entering one's mind need not exit one's mouth!
    As I age my memory fades .... and that's a load off my mind!
    "We Live In The Land Of The Free, Only Because Of The Brave"
    “The problems we face today are there because the people who work for a living are outnumbered by those who vote for a living."
    Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
    13,360
    Maybe rout it out very gently around the grill area so you could fit a bent piece of contrasting venee around it?
    May 2011
    Cape Cod, Ma.
    1,553
    very carefully cut off the corner of the grille where it blew out. then as best as possible cut a filler piece from the same block of wood you cut the grille from and glue that in using the same grain orientation. Once its dry then shape it to the hood with a rasp then re rout. the glue line will be very small if even noticeable. Make the seam so the ends terminate where the radius begins and ends
    13,442
    Maybe cut above the grill all the way to the windshield out and add a new top piece?
    17,472
    i think rich has a good solution but another thought would be to make that tearout area as a added detail that isnt shown on the plan for instance take and grove those all around to make them look like they belong there..
    3,777
    Well thanks for the inputs. Al is definitely correct, walk away. This morning after reading the input here and looking the situation over this is what I came up with. I use the table saw to shave the piece that went across the top of the grill off. Them using a sharp chisel, I smoothed it flat, did some sanding. Cut a new piece to put in there, shaped and fitted it as carefully as I could. Glued it in place. More sanding, a little routing and I'm satisfied. About three hours work.
    17,472
    almost ready for the open road paul these little fixes that we learn from our mishaps are what makes us woodworkers and allows us to do more next time.
    30,014
    That looks great, Paul. Nobody will know it was a fix unless you tell them.
    4,698
    Nice fix Paul, you really can't tell for looking from my end.
