Results 1 to 10 of 16
Thread: Deep Throat Clamp
    SE Minnesota
    2,549
    Deep Throat Clamp
    Some of you may remember the boat cradle I built before Ian was born. It is a little pram with walnut keel and transoms. The planking is 1/8" thick pine with ash ribs. When I was getting ready to plank up the hull, I needed a bunch of clamps with deep throats. All I could find in commercially made clamps with deep enough throats were much too heavy for the application. So, since mother is the invention of necessity, I designed and made my own.
    I mentioned these clamps in Stu's thread about the lightweight box he's working on. I went back to look and found I had the original CAD drawing I made. I imported that into SU and came up with what you see here.
    The jaws are made of 1/2" (12mm) BB ply laminated to 24mm thick . In the background you can see the two halves that make up the lower half of the clamp. I actually started with a long piece, plowed the groove and the rabbet and then cut the piece in half. These were glued face to face to create the hole for the carriage bolt and the groove for the hinge. I made a similar piece with the wider groove for the top jaw.
    After gluing the the plywood together I cut out the jaws using a template. they were nested so as to reduce waste.
    The hinge was made from a scrap of walnut--I started with a long strip, clamped a jaw set together, inserted the walnut strip and cut it to length. By flipping the walnut strip over for the next clamp, I was able to minimize waste there, too. Using the holes drilled in the jaws (located with a jig on the DP) I drilled through the hinge piece while in situ. I drove in a 1/4" dowel dry (no glue) and flush cut it with a little trim saw.
    I used a 5/16" carriage bolt with a washer and wing nut. The carriage bolts shoulder wedges into the square hole in the lower jaw. The slot in the top jaw allows the jaws to open.
    The whole thing went together production line style. I made a dozen clamps in about an hour and a half not counting glue curing time.
    They work very nicely and can apply an amazing amount of pressure. To prevent gluing them to the work I covered the jaws with clear packing tape. there's no finish applied to them although I suppose they'd look nicer if they were finished.
    Thanks for looking.
    If anyone is interested in making some of these, I would be happy to provide the SKP file or make a dimensioned drawing.
    15,811
    Brilliant!
    I think you just saved me a whole lot of cash!
    Did you cut them on the badsaw?
    Big Blue don't like curves, I guess the Phoenix is going to have to get done sooner than later
    11,899
    Great idea. Simple. I like simple. What I don't like is the frustration of knowing I don't have the visual talent to think of an idea like that.
    SE Minnesota
    2,549
    I made these pre bandsaw. I didn't actually nest them as shown. I cut them into rectangular blanks, drilled the hole for the hinge pin using a jig on the DP. The MDF template was cut out with a hand held jig saw and worked to shape. I used a piece of dowel in a hole in the jig to locate that end of the template on the blank. For the other end, I drove in a small nail so the point just stuck out a little. Then I used a bearing guided bit in the router table to cut to shape. If I were doing it now I would indeed rough them out with the bandsaw.
    Not long after I made these I sent the idea to Shop Notes as a tip. they printed it (and paid me) but they butchered it and made a single one from hardwood with mortises cut for the bolt using a mortiser. I thought that ruined the whole idea of mass producing them. Who needs just one clamp for cryin' out loud?
    When I asked them about it they said they though the hardwood would be more durable. It might but the plywood is plenty durable in this application.
    Do you want me to send you the SKP or a dimensioned drawing?
    Frank, thank you. I'm sure you have many other talents though.
    15,811
    Dimensional Drawing would be fine, but whichever is easiest for you Dave.
    SE Minnesota
    2,549
    Stu, I posted the largest image size I could on Photobucket. Here's the link to the image. http://img.photobucket.com/albums/v5...imensioned.jpg Let me know how that goes for you.
    Houston, TX
    363
    Wow Dave, for a minute there I thought you had something going with Linda Lovelace If you don't know who that is you probably are too young to care.
    SE Minnesota
    2,549
    Cecil. I know who she is. Never met her though.
    30,223
    I agree with Stu...brilliant! I'll be putting this one in the "Ideas" file in the event I have a need for something similar in the future.
    15,811
    Quote Originally Posted by Dave Richards View Post
    And you won't, as she is dead.
    Thanks for the drawing, that is great!
    I guess if you made them deeper and also scaled up the size of everything, you could make these fairly large it you wanted to eh?
    Great idea Dave, thanks!
  1. Saw Stop Throat Insert Corral
    Last Post: 03-17-2015, 01:55 PM
  2. Bessey tradesman clamp and edge clamp
    By ken werner in forum Old Ads
    Last Post: 09-13-2009, 08:33 PM
  3. Hello from the deep South . . .
    By Kevin Jaynes in forum Welcome and Introductions
    Last Post: 02-13-2009, 09:24 AM
  4. Stanley 9 1/2 has a sore throat. What do I do?
    By Jim C Bradley in forum Neander Tool Questions and Show & Tell
    Last Post: 05-08-2008, 04:49 AM
  5. Ryobi router table throat plates recalled
    By Jonathan Shively in forum New Tools
    Last Post: 03-10-2007, 04:11 AM
