Results 1 to 6 of 6
Thread: Double Sided Tape
    Dec 2012
    Bedford, NH
    1,683
    Double Sided Tape
    I'm about to exhaust my supply of double sided (DS) tape that I original used for making golf clubs, or for replacing grips, & have since used it for woodworking. It works well, but before I order the golf type DS tape (http://www.golfsmith.com/search?Ntt=double+sided+tape) I'm curious what you guys use for DS tape. Any preferences?
    Thoughts entering one's mind need not exit one's mouth!
    As I age my memory fades .... and that's a load off my mind!
    "We Live In The Land Of The Free, Only Because Of The Brave"
    “The problems we face today are there because the people who work for a living are outnumbered by those who vote for a living."
    Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
    17,475
    well Al i use double sided carpet tape and i know jim delaney has used fast cap double sided tap in some of his projects. what do golfers need double sided tape for?
    Dec 2012
    Bedford, NH
    1,683
    Larry, double sided tape is used for holding the grips onto the shafts. The tape applied to the shaft, then a water-activated grip solution is sprayed over the tape & into the hole of the grip, then the grip is slid over the end of the shaft with the brand name "aligned" with the blade of the golf club, then left to dry overnight.
    5,323
    As Larry said, I've been using the Fastcap tape for most things. It's only a few thousandths thick, and has an unbelievable holding strength. I've actually used it for edge banding, with no other glue or fasteners, and it's holding well after five years (in the case of my sister's 'temporary' countertop) even with a lot of bumping, cleaning, etc.
    I wouldn't use it for temporary sticking something, though. It's too strong. Carpet tape might be better for that.
    Bellingham
    2,449
    Quote Originally Posted by Al Launier View Post
    That reminds me Al, I need to re-grip my clubs. Thanks
    9,077
    I use a few kinds. For odd jobs, I'll use the thicker stuff from the BORG. For permanent solutions I use "transfer tape" which is a thin film like Jim describes. For template routing I need a tape that is thin and one that does not have a rubbery adhesive that allows movement. It is sold as turner's tape and under other names. Unfortunately places like Rockler and Woodcraft source different products for the same item number so you cannot be sure what you are getting. My solution (although this may not help you) is to check the tape wherever I happen to be. Like you I start looking as I get to runing low. If I find a tape that has the characteristics I'm after, I buy it. I know, real scientific, huh? I have had success with Intertape crepe paper core (holds tight and releases well) and Spectape (holds tight but is a bear to get off after about 30 minutes).
  1. Better than double sided tape
    By Jay Caughron in forum Jigs and Fixtures
    Last Post: 04-07-2016, 05:30 PM
  2. Double Sided Coin Project - XYZ Zeroing
    By Brent Dowell in forum Programming, Troubleshooting, and Q&A
    Last Post: 01-18-2016, 02:29 AM
  3. Double sided tape?
    Last Post: 09-06-2011, 08:47 PM
  4. Double Sided Tape
    By Dan Mooney in forum Jigs and Fixtures
    Last Post: 02-01-2009, 08:34 AM
  5. double sticky tape?
    By Frank Fusco in forum General Woodturning Q&A
    Last Post: 10-05-2008, 10:40 PM
