Results 1 to 10 of 12
Thread: Inexpensive Diamond Plates for Worksharp 3000
    After hearing some decent reviews from other folks here and elsewhere I picked up a couple grits of these. The are for lapidary but, are said to last long enough to make them worth the $10. I'll let you know if I find differently. I got a 400 and a 1000 grit.
    They fit perfect. You just back them up with the wheels you already have. I used the one that my 3600 grit film is on.
ID:	80954 . Click image for larger version.
    Here's the result of 400 and then 1000 on my beater chisel I use for glue removal. They cut real quick but, diamonds generally do when new.
ID:	80956 . Click image for larger version.
    I didn't get an finer grits because I wanted to see how the 1000 grit wore. I touched the chisel twice to my regular 3600 abrasive and the results aren't bad for coming right off the machine with no honing. Took about 3 minutes of my time from 400 to this:
    13,361
    Now how did you photoshop that perfect mirror onto your chisel blade?
    I leaned over, craned my neck and took a quick shot with my Canon Rebel. this sometimes works better than others as the auto-focus will sometimes focus on the shiney surface and sometimes on the object that is deeper in the reflection . My camera is smarter than I am but, sometimes not smart enough .
    13,448
    Nice! Added to my wish list.
    London, Ontario
    3,383
    the ws3000 is on my wishlist...
    Tell me, do you use it for your hand plane blades also?
    Nov 2012
    Wapakoneta, OH
    611
    You must have bought the last of the 400 grits, they are now listed as out of stock. I think I'll order one of the 1000 grits discs, though.
    Absolutely. I just touched up the block plane and apron plane last night. I also use it for gouges and I made a holder for shave irons. It is not the be-all end-all in my sharpening arsenal but, it is a blessing when I am doing a lot of hand work. I keep it clamped to the end of the bench. When a cutter starts to lose that just honed edge, I can restore it in a few seconds and carry on.
    Dec 2008
    Santa Claus, In
    4,779
    Glenn, I was lucky enough to find a WS 3000 under the tree this last Christmas, great workshop helper. Was wondering, can you share more about your set up. Looks like you have a stand of some sorts made for it? Did you buy more of the glass wheels? Or are you using MDF like some folks? Anyway, what ever you care to share would be good with me.
    Rule of thumb is if you don’t know what tool to buy next, then you probably don’t need it yet.
    Sep 2007
    Plainwell, Michigan
    4,857
    I also would love to see your set up for shave irons, got some I MUST do that I have procrastinated on long enough
    Quote Originally Posted by Steve Southwood View Post
    The stand build is here. An alternate version that "we" made for dad is here. I picked up additional glass plates during a great sale several years ago while DAREX was still trying to convince folks how cool this thing was. My understanding is that MDF works fine for coarser grits and I know dad has had success with these. As your abrasive gets finer, the irregularities are less tolerated so save your glass plates for your higher grits.
    Quote Originally Posted by Tom Niemi View Post
    Always glad to help (it makes up for my natural orneriness).
ID:	81016Click image for larger version.
ID:	81019Click image for larger version.
ID:	81020Click image for larger version.
ID:	81018Click image for larger version.
ID:	81017Click image for larger version.
    It is a piece of ash with a kerf cut into it. The machine screw holes are threaded and countersunk. The iron is just pinched in place. The screws are your reference (the back of the iron rests against them) so drill the holes and tap the threads accurately at the drill press. I used a fence and stops for positioning the holes. I then put the tap in the DP and turned it by hand with the blank secured in the same position via the same fence and stops; single setup yields accurate result ;-)
  1. Worksharp 3000?
    By Ken Fitzgerald in forum New Tools
    Last Post: 05-14-2012, 12:21 AM
  2. Worksharp 3000 ordered
    By Matt Ducar in forum New Tools
    Last Post: 04-07-2012, 04:19 PM
  3. More Fun with the Worksharp 3000 - Spokeshave Jig
    Last Post: 12-07-2011, 10:39 PM
  4. If your using the Worksharp 3000
    By Bart Leetch in forum Neander Woodworking Q&A
    Last Post: 05-07-2008, 05:29 AM
  5. Nova DVR-3000 and Nova 3000 bed extention close out
    By Stuart Ablett in forum General Woodturning Q&A
    Last Post: 12-20-2007, 04:27 AM
