Results 1 to 10 of 21
Thread: Might have a use for this
    13,427
    When our house was built, it was outside the city limits and on a septic system. Since, the city has grown and the house connect to the sewer system. As part of my Family room remodel I'm taking care of some electrical issues and cleaning up the main panel. One was to remove the old relay box for the septic tank grinder. I'm thinking this has the parts/makings for a dust collection relay system.
Name:	2014-02-08 16.40.17.jpg
ID:	80964Click image for larger version.
Name:	2014-02-08 16.40.30.jpg
    Jan 2011
    3,798
    Recycle, Mmmm good wonder if you sent the dust to the septic tank, if it would break down before filling up
    12,243
    Re: Might have a use for this
    Yeah i would say i agree. Hold on to it. Repurpose it.
    sent from s4
    13,427
    A few updates to the DC switch. For testing I simply added a plug and outlet to the enclosure. I've stripped some of the old components out and have cut and installed external switches and LEDs.
Name:	2014-05-16 21.28.28.jpg
ID:	82955Click image for larger version.
Name:	2014-05-16 21.28.45.jpg
Name:	2014-05-19 21.55.35.jpg
ID:	82957Click image for larger version.
Name:	2014-05-19 21.55.48.jpg
ID:	82958Click image for larger version.
Name:	2014-05-19 22.19.11.jpg
ID:	82959Click image for larger version.
Name:	2014-05-19 22.19.26.jpg
    The spaghetti mess of wires inside and breadboard components will be moved to a pcb once I've tested things out. There is the main power/safety switch, which will kill power to both the controller and to the DC outlet. The yellow button won't be used as a button, just using it's light as a dust bin alert for when it's getting full. The red button is the run indicator light and the manual run switch.
    I plan to mount the controller by the main panel, then will run dedicated power to the box and DC after things have tested out. The old components in the box may or may not get used, will have to see how it all works without any of it.
    Here's an example of the dust bin sensor working.
    http://www.youtube.com/watch?v=dxOG0cJzeLI
    13,353
    Really coming along nicely!
    30,002
    Very cool!
    12,243
    Cool to see you progressing the idea. Are you not worried about dust build up on the IR prox detector?
    13,427
    Not yet. :-) It will hang pointing down, so not sure what to expect.
    Sent from my SPH-L720 using Tapatalk
    Aug 2008
    Reno, Nv
    3,632
    I want to see the "Manual Overide" toggle launch a sewer rocket for zombies!! Sorry...long day (week) in a RPIW...want results!!
    13,427
    Well, disappointment galore. Ran fine when controlling smaller motors (drill and router), but fizzled two 25 amp SSR's with the DC connected. When the LED's went out, it didn't shut off, checked the SSR's with the meter and both were shorted closed. So next is to try either a 40 or 100 amp SSR's or to simply use the mechanical relay in conjunction with a SSR.
