Results 1 to 4 of 4
Thread: Planer Setup
    Herndon VA
    180
    Planer Setup
    My Dewalt 733 planer is starting to snipe on the leading edge after I changed the blades this weekend. Before the blade change everything was fine. I tried adjusting the infeed/outfeed tables so that they would be level with the main table and still get about 1000th of an inch only on the leading edge. It's never on the trailing edge. I even made the infeed a little higher and still not good.
    I know the locking mechanism for the cutter head is working because I just changed a broken locking strap that I found to be the initial issue with it only causing snipe on one side of the planer. I think the strap finally gave way after the blades were changed. The head appears to be locking correctly. Too many gremlins in the shop!
    Any ideas?
    There use to be an online article about this but the web site is no longer around.
    Thanks! Mike
    30,127
    Mike, if I was only getting 1/1000 of a inch of snipe, I'd be kissing the ground and thanking my lucky stars. I get more along the lines of 1/10 inch, on both the leading and trailing ends, but then again I've just got the lowly Delta TP305 Snipemaster.
    Sorry I'm not more help.
    Herndon VA
    180
    Vaughn - I think I got it dialed in now. I adjusted the tables to be slightly on the high side. I'm now down to about 1/2000th!
    I checked an older piece of stock that I plned before the knife change and it seems that my adjustments are an approvement.
    9,088
    Sounds like you've got it Mike. I adjust the in and out tables on my DW734 to be about a dime's height above the platen at the outer edge. Sometimes called 'the ten cent solution'. I tend to run snipe free most of the time. I do get an occasional unexpected snipe now and again but a second pass will remove it (?).
  1. the new pic setup
    By larry merlau in forum Site Questions and Test Posts
    Last Post: 02-15-2014, 09:34 PM
  2. Best Setup
    By Dennis Allen in forum New Tools
    Last Post: 06-13-2013, 01:46 AM
  3. Tormek Setup
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 08-26-2008, 03:54 AM
  4. My Photo Setup
    By Vaughn McMillan in forum General Woodturning Q&A
    Last Post: 07-03-2007, 10:54 PM
  5. Dovetail jig setup
    By Jay Lock in forum General Woodworking Q&A
    Last Post: 05-13-2007, 12:10 PM
