Results 1 to 10 of 15
Thread: peel and stick veneer?
    17,474
    does anyone know if peel and stick veneer will adhere to melamine and stay put after a coat of paint?
    5,172
    Couple of questions. You gonna put veneer on Melamine and then paint it? Why would you do that? If you need a Melamine box with one side of veneer, you can order it that way. Or you can order one side Melamine and the other side 'raw' and then you can apply veneer to that. Whatcha doin'? Not much sticks to Melamine, which is the point of it. Find a sheet goods dealer and see what is offered.
    17,474
    havnt seen any choices of one sided melamine.. this is to be a 24x60 base unit with one exposed wall that will be painted. the interior needs to be melamine
    5,172
    In that case, do a test piece.
    NH
    4,006
    Why can't you paint the inside of a good sheet of ply white?
    Stupid hurts.
    5,172
    'cause he's matching Melamine cabs.
    NH
    4,006
    Yup and they make white paint that matches white melamine That would be the roll and stick veneer
    Or he could go the other way and paint the melamine
    Stupid hurts.
    May 2011
    So. Florida
    268
    If you scuff sand the Melamine it should stick.
    Or, use a paperbacked veneer, and scuff sand the Melamine, and use solvent base contact cement.
    Or, just contact cement " paintable plywood...Maple, Poplar, Birch.
    Or, use " paintable plywood as above, and laminate one side with white cabinet liner.
    Nov 2012
    Wapakoneta, OH
    611
    It's not unusual to see cabinets shops bond one piece of HPL (formica and such) one top of another. If it's works on high pressure laimate, it would work on melamine as well. I'd do as Mike suggested, scuff it really well and put a "bonding coat" of contact cement on it. Let it tack up as normal, then apply the peel and stick veneer. I used that method on a couple of cabinet refacings I did, and the grip that results has to be seen to be believed! Be very sure your veneer is lined up fairly well, one it touches it won't move.
    17,474
    sounds like my best chance fred, wish i had a scrap piece of melamine to scuff sand and see if paint would hold..maybe i should laminate the inside with something and then the outside would be paintable for sure.
    mike you got a source for the cabinet liner you mentioned?
  1. soup stir stick
    Last Post: 03-16-2016, 10:31 PM
  2. Pizza Peel
    By Jeff Bower in forum Flatwork Project Showcase
    Last Post: 05-01-2015, 04:13 PM
  3. HF on a stick?
    Last Post: 12-11-2011, 02:31 PM
  4. Bandsaw Walking Stick
    By Mike Mathieu in forum Jigs and Fixtures
    Last Post: 04-11-2010, 03:42 AM
  5. Neander Push Stick
    By Tom Henry in forum Neander Tool Questions and Show & Tell
    Last Post: 10-17-2007, 06:05 PM
