Results 1 to 10 of 12
Thread: My Spoke Wheel Drilling Jig - UPDATE
    S E Washington State
    3,777
    I want to be able to make spoke wheels for models. Was thinking of doing it on the lathe, making a jig to hold a drill and using the lathe indexer. Looking at the ones I was directed to on the internet, they can be a little complicated. Then I saw a picture on LJ of a jig a model build made to use on the drill press. Looking a the picture, it looked pretty simple to make and use. I made this one. I think the hardest part is going to be centering the blank with the drill bit. I will give it a try tomorrow. The jig was simple to build. I did 24 index holes because that is what my lathe would have had. If I need to make a wheel that uses, say, 16 spokes then I will have to make another wheel to handle it. May just make one anyway just in case. Sure hope it works.
    "We the People ......"
    10,604
    Really cool Paul. Looking forward to seeing your pics of it in action
    Yorktown, Virginia
    5,015
    That will get the job done. Nicely executed Paul
    3,777
    Well, I couldn't wait until tomorrow to try it. AND, IT WORKS!
    This was a test run and I have thought of a couple improvements I can make but I'm happy with it.
    13,450
    Very cool Paul, that would come in handy for sure on other projects. Was thinking the other day about some of the toys I had growing up. One was tinker toys, which that jig would also work for.
    Dec 2012
    Bedford, NH
    1,683
    Looking good Paul, nice job on the jig. You apparently have a good eye for centering the drill to the blank.
    One thing you could do to help would be to establish the front to back center as accurately as you can & then scribe a reference line directly onto the drill press table along the rear edge of the jig base. Then you could use the reference line to visually position the jig in the future, or clamp a block to the line to butt up against. Since centering left to right varies with the thickness of the blank, that would probably remain an "eyeball", unless you want to get more complicated using pre-made spacers for different blank thicknesses.
    Thoughts entering one's mind need not exit one's mouth!
    As I age my memory fades .... and that's a load off my mind!
    "We Live In The Land Of The Free, Only Because Of The Brave"
    “The problems we face today are there because the people who work for a living are outnumbered by those who vote for a living."
    Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
    3,777
    After laying in bed last night trying to breath, what a cold I have, I was also thinking about the jig. Maybe rebuild it. On mine, there is a lot of work to put the blank on and take it off. I have to un-thread the rod that goes through the uprights. If I remade it so the wheel was attached on the outside of the uprights, so to speak, there would only be one bolt to take on and off to put the blank on or take it off. Duh...
    12,258
    Re: My Spoke Wheel Drilling Jig
    Well done Paul. Making jigs in my view is as much fun as making the component or project it goes on. I get bigger kicks out of jigs than the project. Its like making tools.
    Think you will get a lot of pleasure from this one.
    And hey i too would not have rested having got it complete without testing. :thumbup:
    sent from s4
    3,777
    Well this is jig modified. I haven't screwed anything in place yet, but don't see why it wouldn't work. This way it is quicker and easier to get the blank on and off.
    3,777
    Okay, my new spoke wheel jig. Really, time to stop playing around with the jig and get to using it. For the stand and jack I used some yellowheart I've had for a long time. You ask, why the spiraling on the jack. Well I bought a spiral cutter for my lathe, probably 5 years ago and have never tried it. I just could not resist. I got the numbers stamped on the index wheel and only screwed up one. Not bad for an old gummer.
  1. Spoke Shave Rack
    Last Post: 09-28-2012, 08:54 PM
  2. A Spoke File
    By Stuart Ablett in forum Flatwork Project Showcase
    Last Post: 09-13-2012, 01:03 PM
  3. Pen Drilling Jig
    By Raymond Sprouse in forum Jigs and Fixtures
    Last Post: 05-26-2011, 10:25 AM
  4. drilling steel
    Last Post: 05-30-2008, 01:26 PM
  5. Lee Valley Drilling Kit
    By Rob Bodenschatz in forum General Woodworking Q&A
    Last Post: 11-30-2007, 09:09 PM
