Results 1 to 10 of 22
Thread: Need a good plunge router what one?
    Oct 2011
    Cortland NY
    238
    Looking to get a first time plunge router. Have used Porta cable routers in the job shop for many years. I have to say nice but not user friendly in my opinion. Or at least I didn't care for them that much. Have a project I'm setting myself up for and will need a good router to work in hardwood. Cutting mostly dado pockets and such. I'm looking for best for buck if anyone has any advice I'd be glad to hear it. Routers I'd avoid, routers that work best for you that you swear by. I'm in the looking stage and ready to get one in hand soon. So any help would be great. Thanks
    Its too bad manufacturers won't stay consistent enough for me to confidently recommend a brand. I can only state my experience. I have a couple Milwaukee 5616-24 combo routers and mainly use the plunge bases. When I bought them everyone seemed to be singing their praises they were the best feeling plunge mechanisms in a 2-1/4HP router that I had found. The last set I bought was about 3 years ago and it was just as good as the set I bought a few years before that. How they fare this afternoon, I dare not say. I returned a DeWalt set as the plunge mechanism was too sloppy; I could deviate over a 32nd of an inch by applying more pressure to one side and then the other and the plunge would bind and then suddenly move. . . not good for a lot of things I do. This was about 5 years ago and I know a lot of people love their DeWalts so this may have been solved. The Bosch kit get a lot of good press from owners. YMMV.
    P.s. "I have a couple Milwaukee 5616-24 combo routers", oops, just checked, I actually have three combo bases, one came with the 5615 combo. I'm not absent minded, I just happen to have a small herd of Milwaukees . The 5615 ad 5616 motors will swap between any of the plunge an fixed bases so this works well for me. I have bases setup for certain tasks and just load the motor that is appropriate for the task; 5615 is fixed speed but light in weight, 5616 is VS and packs more punch. Needless to say they've been good to me.
    Jan 2014
    Providence Forge, VA
    51
    What's your budget? That has a lot to do with which router is best for you. If you"re interested in decent but cheap I have a SKil 1825 http://www.skiltools.com/Tools/Pages...spx?model=1825 new never used. I got this for a project and then never started the project, so it's still brand new. I have 2 other routers now so I don't need it. It's a good setup and should be great for what you want to do but it's not the best out there. I'd let it go for $50 plus the shipping. If you're interested let me know.
    Earl
    10,600
    For what it's worth I have 2 Porter Cable s, can't remember if they are 690's or 890's. I'll have to go look. Anyway, I really like them.
    Oct 2011
    Cortland NY
    238
    Budget isn't any worry. I need good working machine to do the job. Money will sort it self out. Although that being said I'd think 500.00 to be far to much for any router so there is some limit.
    5,319
    Quote Originally Posted by ed sautter View Post
    The big Milwaukee is really good, and I've heard some good things about the Tritons (but have never used one). For less bucks, but still a good plunger, the Hitachi M12V is good. I've had mine (in a table) for about ten years, and it's been pretty reliable, other than needing the dust cleaned out of the mechanism every couple years.
    Thomasville, GA
    5,992
    Like Jim D., I have an M12V I had in a table for several years. I changed it out last year for reasons totally unrelated to its performance and reliability. I no longer need it, so maybe we can make a deal. PM me, if interested.
    Bill Arnold
    Jan 2014
    51
    I have a Triton MOF001 and it's a great router, the TRA001 is a beast but like most 3+hp routers it's almost to big to use by hand, more suited to a table. I think the 2 , 2 hp routers are about as big as you can comfortably use hand held.
    Earl
    Jun 2007
    4,944
    I have two Tritons (MOF001 C 2 1/4 hp plunge), one Porter Cable (1001 T2), one Ryobi (181 FB) and a Bosch Colt.
    Whenever it is appropriate I use the Bosch Colt because it is light and very easy to use. However, it is for 1/4 shaft tools only and does not have the poop for anything major.
    The Tritons are my favorites. They are identical and run smoothly. The plunge mechanisms operate smoothly and accurately. One of them stays in the router table because the Tritons have above the table adjustments for depth and bit changing. The scale on the above table adjustment is very accurate and gives no trouble making 1/128 inch adjustments. They are very comfortable to use by hand. I tried the TRA001 and, as Earl said, "It is a beast;" it was definitely not for me. I tried a less expensive model Triton and did NOT care for it at all; I returned it---my main objection was a rough plunge mechanism. I cannot remember the model number of that unit. I purchased it at Highland. They took it back with no problem and I purchased another MOF001 C2.
    I have found the Triton MOF001 to have plenty of power. However, I do not own any of the "Monster" class bits.
    I hope this has been helpful for you.
    Enjoy,
    JimB
    VOTING MEMBER
    Nov 2012
    Wapakoneta, OH
    610
    I replaced a PC 690 with a Milwaukee 5616, liked it so well I also bought a 5615 kit. Like Glenn mentioned above, the motors swa=p back and forth, and important to me...several of the PC accessories, like my edge guide, work on the Milwaukees. The Milwaukee has a longer plunge stroke (my main problem with the PC) and they are quite smooth. The motor swaps really easily (another negative with the PC) between bases, and it has a base that can be centered (not the PC). But like Glenn cautioned, Milwaukee was bought out, it would pay to have one in hand (new models) to examine...mine are both about 6 years old.
  1. Plunge router base
    Last Post: 09-25-2010, 02:49 PM
  2. Plunge Router Suggestion
    By Westley Rosenbaum in forum General Woodworking Q&A
    Last Post: 12-11-2009, 05:24 AM
  3. Plunge Router Mortising Jig
    By Ralph Jones in forum Jigs and Fixtures
    Last Post: 04-15-2008, 05:46 PM
  4. the new milwaukee plunge router is out
    By ken werner in forum New Tools
    Last Post: 06-29-2007, 10:37 PM
  5. Plunge router recommendation need
    By Wes Billups in forum New Tools
    Last Post: 06-08-2007, 06:50 AM
