Results 1 to 10 of 11
Thread: Six Panel Doors
    East Freeetown, Massachusetts
    3,014
    Six Panel Doors
    As part of my remodel project I will be changing the doors in my house. I now have luan stained dark walnut. They are OUT - and I will put in new 6 panel - painted White.
    I have 8 doors that I need to paint.
    I hate brush painting ONE 6 panel door - never mind 8.
    TWO - stinkin sides to every door.
    That is SIXTEEN sides.
    CAN I spray them????
    With PAINT.
    I don't really want to go buy the latest spray booth stuff - not interested.
    My big compressor is broken but I do have a high volume piston compressor.
    I have a nice little Kobalt spray gun for polyurethane.
    I was thinking of a LOW END - Kobalt spray gun at Lowes for the water based trim paint - to paint the doors out in my shop.
    What think yee???
    13,427
    I've sprayed doors before and they turned out fine, I setup a drop cloth behind hung from the ceiling. Had two short 2x4's on the floor to set the door on. then one leaned against the wall in front of the drop clothe to only the top edge touched it, that way I could paint both sides and then leaned it against another wall at about a 30-45 degree angle with just the corner touching the wall to let them dry. It let me stack several of them in a short space that way about 3" apart. If you've got any varnish on the doors, scuff them up with some 100 grit sandpaper first to get a good bond before spraying primer. I'd use a gloss or semi-gloss latex for the finish.
    Apr 2009
    Outside the beltway
    5,250
    10 minutes a side each coat, 2 sealers coats and 2 finish coats. Have fun. Get a 4" stainer brush ! It will make the job a bit quicker.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    3,014
    Ohhh - NO - I do NOT want to brush paint them.
    I have painted MORE than my share of panel doors and dentiel molding and all that sort of stuff.
    NO
    I am asking What do I need for a spray gun --- low cost -- Lowes sort of thing --- Kobalt?????
    13,427
    Do you have a link to the gun you're considering? I have an older wagner airless model (similar to this... http://www.homedepot.com/p/Wagner-Op...5009/100661262), works well with the paint thinned properly. Just have to make sure you keep the tank full enough and hold it level. If the pickup tube sucks air it does a nasty spit of paint..
    Apr 2009
    Outside the beltway
    5,250
    Darren for a few $ more you can get a great HVLP sprayer with gun and hose. Check out Spray Fine.
    3,014
    Well - I went to Lowes and I got the Latex version of the gun I have for oil based stuff.
    I guess only time will tell.
    I will be picking up some of the paint tomorrow and I will try to get the ceilings painted this weekend. That is brush and roller.
    Then I really need to get a fire under my you know what and get the beam covers made. THAT - is not a fun thing to me for some reason.
    After that - I think the doors.
    NH
    4,003
    All I am going to say is Dave told you to check out spray fine and you should have listened
    Yes it is more money but some things just can't be done well on the cheap. Spray equipment is one of them things.
    Stupid hurts.
    3,014
    I came home from Lowes with the sprayer before I saw the post about sprayfine.
    I am not really interested in getting setup for spraying, so, I don't need anything great.
    I had a Wagner at one time - sold it in a yard sale.
    I have a Lowes Kobalt sprayer for polyurethane and I have really good luck with that one.
    The Sprayfine looks like several hundred dollars - I don't want to go there.
    If the Lowes sprayer does not work I am out 50 bucks, and I will brush the doors after that.
    This spray job is likely the last time I will use it.
    The painting that I do in the shop is with brushes and rags - not spraying.
    I only want the sprayer - just for this one job - the doors.
    NH
    4,003
    There is always the option to sub the painting of the doors out to a pro painter bet it would be about a hundred bucks a door. Our pro that sprays doors uses one of these Titan Advantage 400 Skid Electric Airless Sprayer it's a bit more jing than the sprayfine. He will spray out a whole house full of doors in an afternoon.
    Stupid hurts.
  1. Raised Panel Cabinet Doors
    By Brent Dowell in forum General Woodworking Q&A
    Last Post: 02-16-2015, 09:14 PM
  2. Raised Panel Doors in SketchUp
    Last Post: 12-31-2012, 03:42 AM
  3. Panel doors question
    Last Post: 07-07-2012, 03:23 PM
  4. Panel Thickness on Cab Doors
    By gary curtis in forum General Woodworking Q&A
    Last Post: 09-11-2007, 09:29 PM
  5. Question re: proportions for raised panel doors
    By John Kairys in forum General Woodworking Q&A
    Last Post: 01-16-2007, 02:32 AM
