Results 1 to 10 of 14
Thread: Cutting plywood, good face up or down?
    Jul 2007
    DSM, IA
    5,719
    I'm gonna be cutting some plywood soon and from google I got different answers as to putting the good side up or down when cutting it. I'll be cross cutting it with a skil saw and then ripping on the table saw.
    What do you all do? Good side up or down?
    My Website
    17,472
    jeff you want to cut it good side down with a skill saw in my book unless you have a zero insert type skill saw like the festool, the ripping on the table saw would be good side up.. you want the teeth pulling the fibers into the wood for best cut side not pulling the out.. but you could use a table saw for the crosscutting as well with help of another person
    S E Washington State
    3,777
    I agree with Larry. I also put tape on the where the cut will be. I find it helps with tear out, although I have had some disagree with me on that. It works for me. Plus, the sharpest, best blade I have. There are also those that will promote using only rip and cross-cut blades, I can't afford all those blades so I use my best combo blade.
    "We the People ......"
    Jul 2007
    DSM, IA
    5,719
    Thanks Larry That's what I thought but read some conflicting things last night while googling. Thought about doing the crosscutting on the TS, but not sure when I'd have help to do it and I'd have to move a bunch of stuff to make room too. I made a "track" for the crosscuts out of some hardboard and ply to hopefully get some good straight cuts.
    My Website
    Jul 2007
    DSM, IA
    5,719
    Thanks Paul, I have a brand new 40 tooth blade for the skil saw and a good 40 tooth in the TS so I'm hoping both will do well. I think I'll give it a go without tape and if there is some tear out, try some tape.
    My Website
    3,134
    Another thing you can do is use the tape & then with a straight edge clamped to the sheet pre-score the cut line with a sharp utility knife.
    Jul 2007
    DSM, IA
    5,719
    Bart, thanks for that as well.
    My Website
    May 2009
    Poway, CA, near San Diego
    174
    Tape works well, but be careful removing it. It can tear fibers out, defeating the purpose.
    Jul 2007
    DSM, IA
    5,719
    Yep Bob I saw that you should pull the tape towards where the cut edge and down when removing it so you don't pull the veneer fibers up from the inner play parts.
    My Website
    Feb 2012
    2,748
    Good side down with the skilsaw. Up with tablesaws!
    Cheers,
    Roger
  1. Plywood cutting jig
    By larry merlau in forum Jigs and Fixtures
    Last Post: 12-30-2012, 12:51 PM
  2. Chocolate cutting board, and cheeseboard complete with Holy face...
    By Roger Tulk in forum Flatwork Project Showcase
    Last Post: 07-24-2012, 12:09 PM
  3. Why Face Shields Are Good
    Last Post: 07-26-2010, 05:33 AM
  4. TS blade for cutting plywood.
    By Mike Grimm in forum General Woodworking Q&A
    Last Post: 06-01-2009, 05:35 PM
  5. Plywood is good for turning!
    By Michael Robertson in forum Lathe Project Showcase
    Last Post: 03-18-2007, 03:26 PM
