Results 1 to 3 of 3
Thread: Stu's table legs....
    Stu.....I started turning some spindles for the wheel on Dave Richard's sail boat last night! Turning pummels is exciting......actually,...it's not the turning of the pummels that's exciting.....it's the turning you do after you turn the pummels that's exciting!
    Did you know that square corners will rap your knuckles at 4 times the speed you have lathe set at....even it you have a skew in your hand?
    Did you know that the same thing happens when you are sanding?
    I now have more appreciation for the table legs you turned recently!
    Steve Clardy Guest
    Oh ya.
    Them square corners are hard
    How many bandages have you used
    15,811
    Yep, them pommels can pummel you for sure
    Speed is the key, the faster the better, really.
    I turned my pummels at about 1500 rpm, any slower and I had more trouble, and you really, REALLY have to look at the top side of the spindle, not the skew that is doing the cutting. Sharp, and I mean shaving sharp edge and a fairly stout skew help as well.
  1. Table legs
    Last Post: 03-17-2016, 02:49 PM
  2. tapered table legs
    By Mark Kosmowski in forum General Woodworking Q&A
    Last Post: 04-06-2010, 01:10 AM
  3. NIB Delta Unifence/Table/Legs 36-U30 $100
    By Scott Weiss in forum Old Ads
    Last Post: 09-21-2007, 02:07 AM
  4. Hall Table Legs
    By Ben Roman in forum General Woodworking Q&A
    Last Post: 02-22-2007, 03:00 AM
  5. Table Legs......?????
    By Stuart Ablett in forum General Woodturning Q&A
    Last Post: 02-05-2007, 10:32 PM
