Results 1 to 5 of 5
Thread: Lowe's Adjustable Saw Horse Modification
    I usually make this sort of thing but, the combination of dealing with a failed water heater, a personal project for the house that is taking too long and a Lowe's gift card from a well intentioned admirer led me to pick up a couple of these in the dent and ding bin. I love my two height assembly table and use the legs with and without the table top. The tallest height was a bit low for the current project and the benchtop was too high. The saw horses adjust but, the lowest height is about 25" which is about as high as I would ever need. I lopped the legs off and drilled a couple new holes for the wingnut and bolt that secure a given height selection (along with the keyhole pins like a lot of quick-assemble metal fixtures use).
    I figured out a height that would meet my needs and leave the height adjustment mechanism functional. I wanted to knock about 9" off of the height so I cut a piece of scrap to this height. Using this as a marker got my height and angle in one shot.
Name:	Saw Horse Mod (1).jpg
ID:	81503 . Click image for larger version.
Name:	Saw Horse Mod (2).jpg
    Here's the result at the lowest and middle height.
Name:	Saw Horse Mod (3).jpg
ID:	81505 . Click image for larger version.
Name:	Saw Horse Mod (4).jpg
    And here they are at their new highest setting. My aching back feels better already .
Name:	Saw Horse Mod (5).jpg
    17,474
    glenn are those legs sturdy? they claim to be able to hold 1200 lbs??? no chance of them folding up easily? on there own
    Sacramento, CA
    1,367
    I have a pair of those as well and absolutely love them. They're a little wobbly side-to-side, but not that bad. They have a real heavy steel tab that makes folding up on themselves impossible when the legs are fully open. Work great.
    I recently had to use 'em in the house and didn't want to ding up the tile floor so I made some feet for mine that worked out really well...
ID:	81508Click image for larger version.
ID:	81509Click image for larger version.
ID:	81510Click image for larger version.
ID:	81511Click image for larger version.
    Oh - and a shot of them in use...
    Jason Beam
    Sacramento, CA
    I was doubtful too but, ready many good reviews by folks who use them harder than I would. Still I set them up at maximum extension (before shortening) and laid about 400lbs of lumber on them and stressed them; they seem even more stable under load. They are definitely built in such a way that they require a proper stance for reliability. That is; if you were to get them strained at the joint beyond their restricted range of motion (Give me a long enough lever and I will move the world ), I have no doubt that they would fail despite the gauge of the metal (appears to be about 20 gauge). I clamp the I-beams to them which creates a very solid base.
    P.s. Jason, cool idea on the little feet.
    Jun 2007
    4,944
    Jason,
    Those feet are a neat, simple way to solve a problem. Good thinking.
    Enjoy,
    JimB
    VOTING MEMBER
  1. Bessey clamps at Lowe's
    By Jay Caughron in forum Hot Deals
    Last Post: 06-08-2014, 03:29 PM
  2. A good word for Lowe's
    Last Post: 06-04-2011, 12:06 AM
  3. YMMV: Hitachi SB10Y Disc/Belt Sander at Lowe's $50
    By Jeff Bergman in forum Hot Deals
    Last Post: 02-16-2010, 11:59 PM
  4. 14" Delta Band Saw @ Lowe's for $250 (YMMV)
    Last Post: 01-28-2010, 05:24 PM
  5. PC 342K - $33 at Lowe's
    Last Post: 03-17-2008, 07:05 PM
