Results 1 to 6 of 6
Thread: Nexabond 2500
    Apr 2009
    Red Deer, Alberta, Canada
    1,083
    Nexabond 2500
    Has anyone tried Nexabond 2500 adhesive made by Bioformix Inc.?
    It is a new Cyanoacrylate adhesive formulated expressly for woodworking.
    David Helm has been doing woodworking demonstrations using Nexabond.
    Les
    Innovation is the process that renews something that already exists and not, as is commonly assumed, the introduction of something new.
    Constantine, MI
    7,890
    Nexabond 2500
    I just used it today for the first time. For the application I needed it for it was perfect and worked very well. I had some half-inch MDF panels for drawer fronts that were set into a rabbet in a popular frame. A very small bead around the inside of the rabbet and then pressed the MDF into it and clamped for 10 minutes was all that was required. A nice tight bond although it will never really be tested for stress it did what I needed to do.
    www.wrworkshop.com
    Yorktown, Virginia
    5,015
    I've been looking at it, but with all the stories about CA it's got me wondering.
    Quote Originally Posted by Les Elm View Post
    Les
    I have the short (1 to 3 min) and long (3 to 5 min) open time and have used them quite a bit over the last several months. They work great and are now indispensable. They are a little pricey but when you need to get something bonded quick it is my go to glue.
    Jack
    Aug 2008
    Reno, Nv
    3,632
    What have you tried Les and are you willing to share your results?
    Apr 2009
    1,083
    Jim,
    I haven't tried any yet.
    Les
