I think the best option is a composite material. You can get fibers to embed in epoxy: the combination will stick well and be tougher than anything else. An epoxy matrix with glass fibers is pretty far from brittle. I don't recall what material is used for the microfibers commonly mixed into epoxy for use as glue. If you contact one of the companies that sell a range of types of high quality epoxy, you can get good advice on what will fit your application. System Three and West are among these companies. I have had excellent results in different circumstances with at least 5 different System Three epoxies, and they have lots of good info available on their website.
You might even want to consider encapsulating the wood inside fiberglass/epoxy, as is done with woodstrip canoes. It looks like wood, and is very strong.
Thanks for the input Alan.
Epoxy here in Japan is a bit of a hard nut to crack, the cheap simple stuff you can get but it all dries rock hard, the higher end stuff exists, but it is used mainly in industry and when I've found someone who will sell it to me, it is usually in large formats that I'd never use. I know that most of the epoxies will not ship overseas either.
At this point I'm fairly sure I'll go with basic Titebond II or III but I might also try some Plastic Resin Glue like Charlie and other have suggested. I've read that it is as strong as the yellow glue with the added benefit of a very long open time, which when you are putting something like a chair together would be nice.
We shall see.
I went down to my wood supplier
Nakajima Company to see about the price of Beech.
The owner's son who I usually talk to was busy, so I was talking to one of the workers and he was showing me some European Beech, all about 3M (10') long and from about 20cm to 25cm (8" to 10") wide and from 27mm to 66mm (1-1/4" to 2-1/2") thick.
Even the thickest boards they had would not be thick enough to make the two rear legs and back rest pieces of the chair, I need something closer to 70mm (2-3/4") square to make that leg. OK, I thought, I'll just have to glue up two pieces. Then the owners son comes over and we start chatting, I show him the picture of the chair and the blueprints and we talk about the options, then he sort of goes "Wait a minute, a chair...?" and we go over to a different part of the storehouse and there are stacks and stacks of pieces of wood there from about 1" square and 18" long to a full 3-1/2" square and 30" long....
Perfect, I say, what is the wood, he say European Beech, I ask what the pieces are for, he say "Making chairs"
we had a good laugh.
Much cheaper than flat long boards too, and they are completely clear, as they are for chairs, good solid straight grained beech.
When I was about to leave he pointed to some wood and asked if I ever use Oak, I said that I did not use much of it, she showed me some European Oak, that was about 6" wide 5/4 thick and maybe 10' long, some of it he had sliced down the middle so it was now about 2/4 thick, he gave me one piece as it was from the outside of the stack and had some stains on it.
Not much of a piece, but is sure has some nice rays in it, the piece I have was about 10' long, 6" wide and 1/2" thick, but to store it easier I cut it in half, so two 5' long pieces. I'm sure I'll find some use for it.
Just a little update.
