Results 1 to 10 of 11
Thread: Sander
    NH
    4,003
    Sander
    Ok guys it's need to know time wide belt or drum which is better and why? I know which cost more money
    Stupid hurts.
    May 2011
    Cape Cod, Ma.
    1,553
    Ive used both, I have a drum. Would say if its in the budget go widebelt. the belt will not fetch up as easily as the drum and not wear a trench in your stock. Also, with the platen you can control the pressure of the paper on the stock. Also, a widebelt is going to be a bit more accurate.
    Another is the ease of changing paper. its easier to open a door release the tension slide out one belt slide on another reset tension and go. With the drum you have to cut your paper to length and wrap/unwrap it each grit. doesn't sound like a lot but when you do it a few times you start to see the benefits.
    Anyway, hope that helps
    4,551
    Wide Belt. You can also wash the belts at the car wash and use for a LONG LONG time. Plus like Rich said changing paper is a breeze. A wide belt is the fist thing I bought when I move to the new place and Not one regret.
    And just as a side note I never seen a need for anything bigger than a 24" most of the time you are just sizing stock. I love me 16"
    A Turn N Time
    Frog Pond Guitars
    Central PA
    638
    I have a drum sander, I suppose the wide belt is probably always better, but depending on your intended use a drum sander may be perfectly suited. My drum sander works great for what I need, I built the sander myself. Mainly I use it to level glued up panels and table tops. I have hook and loop paper on it so it doesn't flatten as perfectly as straight paper on a dry,m buts thats not really an issue for me. I don't have any paper burning issues, I think that having a large drum (8") and good dust collection is the reason for that.
    http://familywoodworking.org/forums/...ot-drum-sander
    NH
    4,003
    Thanks for the input guys. The more I look the more it seems a wide belt is the way to go. Good thing a wide belt machine is the same price as a compact car.
    Stupid hurts.
    4,697
    Don't forget the DC issue. Wide belts like a lot of dust collection. I can get by with my little DC on my drum sander wouldn't even consider trying to run a wide belt with it.
    NH
    4,003
    A Laguna 51" almost cost more than my truck
    Stupid hurts.
    17,470
    have DRUM but wished i had a wide belt.. and get as wide as you can chuck..
    NH
    4,003
    But the Laguna TS is very reasonable on the price.
    Stupid hurts.
    Austin, Texas
    1,447
    I have a 38 inch 5 hp drum sander, and sure wish I had saved my nickels for a wide belt.
    The hook and loop paper on the drum, combined with the relatively thick rubber feed belt, makes thickness far less accurate than when I had the cheap Performax (Jet). I can make three passes, and still remove material, without adjusting the depth. If I have run narrow boards, it is easy to bugger the paper, and then it will leave shallow grooves in the wider panels. I have a 5 hp dust collector with a 6 inch hose connection (close to the cyclone), and I still get piles of sawdust on the floor near the outfeed, but I MUST run the DC.
    For years I considered the Speedsander by TimeSavers to be inferior quality, even next to the Grizzly wide belt. Then I saw four of them in use in a cabinet door factory (don't bother adjusting the depth, just go from one machine to the second, then flip the doors over and two machines for the backs. In use 8 hours per day, so I don't think the quality can be too shoddy. As I near retirement from my retirement job, I don't know if I will ever make the step up, but I wish I had taken this step rather than my big drum sander.
    Jim Hager did a review of the TimeSaver sander back in 2008 - http://familywoodworking.org/forums/...s-Speed-Sander
    Last edited by Charlie Plesums; 03-16-2014 at 02:43 AM. Reason: Add link to Jim Hager's review
    Charlie Plesums, Austin Texas
  1. Air Sander
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 12-29-2011, 02:28 AM
  2. New sander
    By Don Baer in forum New Tools
    Last Post: 02-02-2010, 04:12 AM
  3. Belt Sander or Orbital Sander
    By Dawson Mossman in forum New Tools
    Last Post: 09-18-2009, 01:03 AM
  4. new sander
    By Dan Noren in forum New Tools
    Last Post: 02-27-2009, 11:49 AM
  5. Belt Sander vs a Drum (thickness) Sander
    By Ken Close in forum New Tools
    Last Post: 11-26-2007, 01:36 PM
