Results 1 to 4 of 4
Thread: Kreg screws with OSB?
    Mar 2014
    Michigan
    144
    What are your thoughts of using Kreg screws with 1/2" OSB?
    Yes, I'm needy today. Don't know what I did without you all.
    Kevin
    In arte voluptas - in der Kunst liegt Vergnügen - in art lies enjoyment
    I wouldn't pocket hole into OSB but, if you are talking about just screwing it to studs, I see no problem with a particular screw brand. It is the head format that I would want to be 'flat head' so as to be flush as opposed to pan or washer head. Depends on the application I imagine.
    Mar 2014
    Michigan
    144
    Thank you, Glenn
    Kevin
    By the way, I used 7/16" primed and painted OSB for a portion of my shop walls. I use a cleat system screwed through to the studs so I don't rely on the OSB to hold screws itself but, at the time it was a very inexpensive wall sheeting material. Today, 3/8" ply is about the same cost around here so we used that on dad's shop walls.
  1. Kreg Pocket Hole Screws
    By Charles Hans in forum Hot Deals
    Last Post: 01-28-2012, 04:29 PM
  2. How much for screws?
    Last Post: 11-02-2010, 12:21 AM
  3. Where do you buy your screws?
    Last Post: 05-17-2010, 03:23 PM
  4. Kreg Pocket Screws and Bits question
    By Bob Wiggins in forum General Woodworking Q&A
    Last Post: 01-15-2009, 12:37 AM
  5. Help with screws
    By Chuck Beland in forum General Woodworking Q&A
    Last Post: 01-30-2008, 02:30 AM
