Results 1 to 6 of 6
Thread: Ridgid sander modification
    10,600
    Like AL I had to use my ridgid spindle sander to sand a bandsaw box that was wider than the stroke of the sanding drum. I was short a little more than 1/2"
    I noticed that a little more than 3/4" of the drum/sleeve always stayed below the base plate.
    Digging around in my cans of stuff that I toss miscellaneous hardware in that I've been planning on sorting out for 10 years I found some nylon bushings that looking like they would work
    This one is about 1/2" thick with a 1/2" hole. It fits the spindle perfectly. I think that I have more around somewhere but I know that Lowes and my local hardware store sell this size and many other sizes.
    I simply added the bushing to the top of the drum, pulled the sanding sleeve up until it reached the top and screwed it tight. Now I have an additional 1/2" of sanding capacity and up to 1/4"more with a thicker bushing.Click image for larger version.
ID:	82032Click image for larger version.
ID:	82033Click image for larger version.
ID:	82034Click image for larger version.
ID:	82035Click image for larger version.
    Works like a champ
    That rocks. Well done.
    13,431
    Great tip Bob! I've got that sander as well, has annoyed me that the bottom never gets used. Will typically slip the sanding sleeve up to use it but depends on the size of the sleeve.
    12,246
    Re: Ridgid sander modification
    Thanks Bob i got same sander will look to do the same mod.
    Sep 2007
    Plainwell, Michigan
    4,855
    [QUOTE=Rob Keeble;398674]Thanks Bob i got same sander will look to do the same mod.
    Ditto and thanks Bob
    Dec 2012
    Bedford, NH
    1,683
    Creative solution Bob! Thanks for the tip! I'm going use it for sure. In fact, I'm heading for the shop right now to see what I can scrounge up some bushings and/or take some measurements to get some at HD or Lowes.
    Thoughts entering one's mind need not exit one's mouth!
    As I age my memory fades .... and that's a load off my mind!
    "We Live In The Land Of The Free, Only Because Of The Brave"
    “The problems we face today are there because the people who work for a living are outnumbered by those who vote for a living."
    Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
  1. Edge Sander Fence Modification
    Last Post: 12-11-2014, 02:08 AM
  2. Replies: 24
    Last Post: 10-01-2013, 01:28 PM
  3. Ridgid Sander Stand
    By Rich Aldrich in forum Flatwork Project Showcase
    Last Post: 01-25-2010, 01:19 AM
  4. Ridgid EB4424 Sander DC Fix - ver 2
    Last Post: 11-23-2009, 05:04 AM
  5. Ridgid Spindle/ Belt sander EB 4424
    By Rich Aldrich in forum New Tools
    Last Post: 04-03-2009, 02:27 AM
