Results 1 to 4 of 4
Thread: Phenolic tapped holes
    12,251
    Yeah this is not quite woodworking but it is in a indirect way.
    I have just pulled the trigger and purchased a Jessem phenolic router table top to go with my Jessem router lift i purchased a year ago and have not made a top for yet.
    Anyway to attach it to the cabinet i intend to build in the year 20XX i am using 1 inch aluminum angle iron.
    The top has predrilled and tapped holes underside and is supplied with 1/2" 10-24 cap screws for this purpose.
    I first ran a tap through all the holes just to clean up the threads (many were not quiet clear) .
    Now i am wondering should i bother to use locktite blue or not. Will it affect phenolic or best just leave well alone. I am thinking of the vibration that is bound to exist and dont wish to have to get inside the cabinet i make and have to tighten cap screws.
    I know of phenolic but have never worked with it ever. This is an "old" electrical insulating material to me but thats all i know of it in practice.
    Any mechanical boffins out there know what i should do.
    Could settle for a split washer and no locktite.
    Thanks for any help and suggestions.
    17,472
    my router top has been made out of the phenolic rob and no locktight used and its held up for years..
    Dec 2008
    Santa Claus, In
    4,779
    I think I would go without for now. Run it awhile and see if they get loose. Then maybe think about loctite
    12,251
    Thanks guys will do the same, its easier too.
  1. MDF and dog holes?
    By Ken Cook in forum General Woodworking Q&A
    Last Post: 12-05-2014, 09:26 PM
  2. Questions about phenolic?
    By Alan Bienlein in forum General Woodworking Q&A
    Last Post: 11-02-2012, 12:11 PM
  3. Phenolic of UHMW in Thin Sheets?
    By gary curtis in forum General Woodworking Q&A
    Last Post: 01-04-2009, 02:36 PM
  4. Anybody here interested in a small phenolic sheet?
    By Mark Rios in forum Hot Deals
    Last Post: 08-31-2008, 08:16 PM
  5. phenolic plywood
    By Doug Sinjem in forum General Woodworking Q&A
    Last Post: 05-09-2008, 08:56 PM
