Results 1 to 10 of 20
Thread: Delta DP Trunnion Fail - Update
    9,077
    I blame Rob . Just when I posted in his 'DP Quest' thread about how much I like the Delta woodworking DP table design and how much I use it, it fails!
    Here's the general design that allows the table to tilt forward and back. the second shot shows the minor fail on the left trunnion.
Name:	Delta DP Fail (1).jpg
ID:	82089Click image for larger version.
Name:	Delta DP Fail (2).jpg
    Here is the total fail of the right trunnion block.
Name:	Delta DP Fail (3).jpg
    Now before my dad starts telling you how I tend to tighten things like a gorilla [let's all remember he broke his banjo of his lathe ] despite my 5'-10" 175lb frame, let me show you the size of the handles they provide for torquing this thing down. The table is quite beefy at about 25lbs. The handles look and feel like they are designed to allow an easy tightening . . . maybe too easy.
Name:	Delta DP Fail (4).jpg
ID:	82092 . Click image for larger version.
Name:	Delta DP Fail (5).jpg
    You can see the design flaw. The locking block rides on a couple of "blades" that set in a couple of grooves in the trunnion. There is, however, no limiting mechanism designed into the casting which allows the resulting energy from the torque to focus at the bolt head.
Name:	Delta DP Fail (6).jpg
ID:	82094Click image for larger version.
Name:	Delta DP Fail (7).jpg
    This was one of maybe two redeeming characteristics of this DP. I don't know if parts are available but, I will try to get them and modify it to be less destruct prone if possible. Those of you with similar table designs, Delta or not, may want to take a look under the hood before things go south.
    A few minutes later . . . .
    Well, that figures:
Name:	Delta DP Fail (8).jpg
    I'll try elsewhere.
    A few minutes later still . . . .
    ereplacementparts usually has everything but . . .
Name:	Delta DP Fail (9).jpg
    I found them here. We'll see if they actually show up
    Jan 2011
    3,798
    Bummer ....Rob hit his so hard with that mallet, the resulting vibrations are surely the cause of yours letting go
    Hope you find an ea$y fix!
    Independence, Kentucky
    1,355
    I would take the one that is cracked to a local machinist and have a pair of them made from steel. That isn't a place for a cast pot metal or aluminum part.
    Sacramento, CA
    1,367
    Obsolete, eh?
    Did maybe delta redesign them for this very reason? I wonder if there's a recall -- maybe you can get delta to replace 'em on their dime?
    Jason Beam
    Sacramento, CA
    12,264
    Oh boy my apologies Glenn for the "negative vibes man". (Oddball aka Donald Sutherland ..Kellys Hero's) .
    Delta pot metal what can i say. I agree with Charles, thats the wrong place to use cast ally.
    Those trunion adjustments remind me of my table on my Delta Bandsaw uses the same kind of method if not the same part.
    Here is my saw diagrams check out the table http://www.ereplacementparts.com/del...3481_3494.html
    here is the shoe they have on the trunnions for the bandsaw table looks the same to me.
    http://www.ereplacementparts.com/cla...e-p-84680.html
    I thought this was a relatively new model drill press. What i read about it on amazon and the quality makes me think they picked the wrong taichi suppliers to make it.
    Pretty hi tag price but lots of nice features by the looks of it.
    Hope you get things sorted Glenn.
    4,701
    Yikes. Now I'm afraid to look.
    9,077
    I believe a steel clamp shoe might be too much for the pot metal cast trunnions . I found them for about $3 each and so ordered them. I may make a better version out of white oak or ash if I cannot modify the original to be more regulating. The design almost assures failure after some years of use. I suppose if you never used the feature that they bragged on so much when this DP came out, you wouldn't have a problem. I would have a hard time going back to a table that only tilted left to right.
    5,323
    Glenn,
    Those trunnions look like the same ones used on Delta's 14" bandsaw. If that's the case, you ought to be able to find them in nearly everyone's bandsaw parts catalog.
    I know the bandsaw trunnions pretty much interchange between all the brands. I have Delta trunnions on my TaiChi saw. If all else fails, take a look at the Grizzley G0555 parts list.
    9,077
    Glenn,
    Very similar but, the part # doesn't cross reference (that doesn't mean much though). They are a match for all these:
    • Emglo 5140029-82
    • DeWALT 5140029-82
    • Devilbiss Air Power 5140029-82
    • Delta 5140029-82
    • Black and Decker 5140029-82
    • Biesmeyer 5140029-82
    • Porter Cable 5140029-82
    I have been looking at the one that is only cracked and feel quite confident that I can come up with a preventative modification. If I succeed I will post it as these same parts are on the 17-950 and the 17-959 so maybe it will help some folks if I am successful..
    Jan 2014
    Providence Forge, VA
    51
    I juts posted in Rob's thread about how much I like my Delta and then I read this thread, I hope mine is not going to fail now.
    Earl
  1. Extension table fail
    By Carol Reed in forum Old Iron
    Last Post: 03-20-2015, 12:31 AM
  2. Roger's never-fail French style bread recipe
    By Roger Tulk in forum The Cook Shack
    Last Post: 02-13-2015, 04:43 PM
  3. Delta Planer - DELTA 22-795X 15-inch\ 3 HP
    By Doug DeVore in forum Hot Deals
    Last Post: 01-09-2013, 02:27 PM
  4. An update on the Grizzly riser on a Delta saw
    By Chuck Ellis in forum Off Topic Discussion
    Last Post: 02-19-2011, 12:47 AM
  5. New to me Delta DJ-20
    Last Post: 01-14-2010, 01:42 AM
