Results 1 to 5 of 5
Thread: jet 1642 bearings
    Mar 2011
    Gulf Coast MS
    8
    jet 1642 bearings
    I just changed he bearings on my 1642. I did it because you could grab the end of the shaft and physically move it to make a clunk. I changed the bearings to the Japanese sealed bearings. All went well. Unless I tighten the jam nut very tight I still get the clunk. Does this mean I need a new wave washer. Also the front bearing seems to get hot. When I put in a drive center it is very warm to the touch when I take it out. I would appreciate any help from anyone who has changed the bearings in a Jet 1642.
    Thanks
    PS: Took it apart again this morning. I seem to be running out of threads with the jam nut. hmmm.
    Too bad I don't have a service station near here.
    S E Washington State
    3,777
    I can't answer but this may help, I don't know.
    http://www.sawmillcreek.org/showthre...t-1642-Bearing
    "We the People ......"
    North West Indiana
    6,097
    Quote Originally Posted by Larry Matchett View Post
    Thanks
    All nomenclature is coming from this source: http://www.ereplacementparts.com/jet...54_155051.html
    I will assume you are talking about the tailstock. The clunk you refer to could be happening because your handwheel is not moved far enough forward on your lead screw which screws into your quill. So, loosen the tailstock quill handle, slide the quill (which slides the lead screw) back as far as you can (maybe even make the clunk sound). Then tighten your tailstock quill handle and check the distance between your handwheel and tailstock. If there is a gap, loosen the allen screws on your handwheel and slide it forward on the lead screw. This will take up the slop and should reduce the clunk sound.
    The heat you mention I assume is now at the headstock. You are turning between centers using a spur drive? If so, is it fitting correctly or not slipping on the inside creating heat from friction? Are you grossly overtightening your tailstock causing your bearing to push against the headstock and creating friction?
    Jon
    30,002
    Quote Originally Posted by Jonathan Shively View Post
    ...I will assume you are talking about the tailstock...
    Jon, I'm pretty sure Larry's talking about changing main bearings in the headstock. That's where the jam nut and wave washer are.
    North West Indiana
    6,097
    Sorry, Vaughn is 100% correct, on the schematic I provided as a link, second page B-9 is the wave washer. Well, just disregard all of my advice, shows you get what you pay for!!
    Jon
  1. Bearings on router bits
    Last Post: 05-11-2012, 09:05 PM
  2. Delta 14" Bandsaw bearings
    Last Post: 04-17-2012, 05:06 AM
  3. Rockwell 46-111 Bearings
    By Ron McClane in forum General Woodturning Q&A
    Last Post: 02-15-2010, 03:55 PM
  4. Quality Source for BS Guide Bearings?
    Last Post: 08-16-2009, 10:32 PM
  5. New guide bearings on the Craftsman 22401 14" Bandsaw
    By Jim Fancher in forum New Tools
    Last Post: 02-27-2007, 02:28 PM
