Dave Hawksford
- Outside the beltway
Both were coated with Minwax tung oil (5 coats) then buffed out with Behlin Buffing compound. Like glass , Very simple process. Sanding in between coats with 320 Finial sand with 1000 grit wet. Apply one more coat and buff. The buffing is the hardest part. I used a bit of Naphtha with the compound. I also worked the tung oil like I would a french polish when applying it.
