Results 1 to 10 of 11
Thread: Seat cover project stymied
    5,172
    Got one arm rest off. Can't get the other one. Need to find a guy with a pneumatic ratchet and a big Torx driver.
    But no more time now to work on it before I leave.
    Darn, I wanted a comfy seat under my tush.
    17,472
    hey carol those little hammer hit ram sets will do the job on most cases to get something loose enough to do the rest with a rachet..
    5,172
    I have a hammer screwdriver. It has a replaceable tip. Would have to get the proper Torx driver, which I really don't want to own one of. and I'd have to find it! No small task there either. Then there is the four hands necessary to do this.
    The guy at the auto parts store tried to get it off. He got one off. I held the rest down and put a light on the subject for him. He had to hold back the foam stuff and crank away. The first one was hard to break loose but then it went OK. We switched to the other one and he was bending the bit. He slipped off twice rapping his knuckle a good lick and we called it quits. When they get off, they're headed for the trash.
    So next up will be a pneumatic driver when the opportunity presents itself. Also I thibnk to use the hammer devise, I'd have to take the seat out to get some swinging room.
    But thanks for the thought.
    Back to packing.
    North West Indiana
    6,099
    If you are not going to reuse them, cut the head off with a cut off wheel.
    Find someone with a MIG welder, big nut, set on the torx head, weld the inside of the nut to the torx head, while hot use a ratchet and socket and remove the bolt.
    Jon
    13,450
    Bring it along and we'll hopefully get you a comfortable ride for the way back home. I've got impacts, torx bits, and if need be a welder.
    North West Indiana
    6,099
    There you go! A man with a plan!!!!!!!!!!!!!! Great job Darren!!!!!!!!!
    Jon
    13,361
    There you go. Darren will get you fixed up!
    Maybe you could use a little pillow or something for the ride out.
    I envy you. I love going on long road trips.
    Drive safe!
    Vaya con dios!
    Sep 2007
    Plainwell, Michigan
    4,857
    Safe travels Carol, looking forward to pics
    5,321
    Got one arm rest off. Can't get the other one. Need to find a guy with a pneumatic ratchet and a big Torx driver...
    Check for left-handed threads on that side.
    North West Indiana
    6,099
    Ohhhhhhh, excellent idea Jim! Hadn't considered that as an option and very well could be a possibility. Remember the old Dodge trucks had left handed threaded studs on the wheels for passenger side.
    Jon
  1. Truck under seat storage
    Last Post: 06-08-2015, 11:22 PM
  2. Truck seat cover upholstery help
    Last Post: 04-15-2014, 06:59 PM
  3. window bench seat,project COMPLETED!
    Last Post: 07-01-2011, 03:35 PM
  4. can this seat be saved?
    Last Post: 11-13-2009, 01:52 AM
  5. seat cushion foam
    Last Post: 04-12-2009, 10:24 AM
