Results 1 to 3 of 3
Thread: Once Fired................
    Apr 2009
    Red Deer, Alberta, Canada
    1,083
    M2 .50 Caliber Ball Projectile 706.7 gr (45.8 g) The M2 is the original standard .50 caliber ball projectile with a hardened solid brass jacket, hardened solid brass tip and a solid steel core crowned with lead.
    These projectiles are 65-70 years old and are undamaged due to being fired into lake ice on an old 1940's winter military firing range.
    I just cleaned up with some steel wool in order to not damage the projectile rifling.
    You can tell how worn out some of the rifle barrel must have been by looking at the depth of the projectile rifling.
    Les
    Innovation is the process that renews something that already exists and not, as is commonly assumed, the introduction of something new.
    Dec 2013
    North Okanagan
    83
    Wow, so where do you find these bullets?
    "If they don't know you personally, don't take it personal."
    30,017
    Wow, those are very cool, Les. I really like the rifling marks.
    The last time I went desert shooting (out on public lands, not a structured shooting range), I was picking up empty shell casings and found a once-fired .45 caliber FMJ bullet. Not sure how it got there, as I was picking up brass in the area where shooters stand, not anywhere near the hillside being used as a backstop.
  1. fired up the Lathe
    By Dave Hawksford in forum Lathe Project Showcase
    Last Post: 12-08-2015, 11:32 PM
  2. What is Inside Your Gas Fired Furnace?
    By Scott R Smith in forum Off Topic Discussion
    Last Post: 11-15-2014, 03:31 AM
  3. Fired up the TS
    By Ned Bulken in forum Flatwork Project Showcase
    Last Post: 09-12-2011, 02:35 AM
