Results 1 to 1 of 1
Thread: Spray Finish on Turnings
    Palm Springs, Ca
    1,169
    I decided to start another thread regarding spray guns/devices after some of the comments on my previous thread regarding Deft Acrylic being junk. So the reason I like the Deft spray cans of Lacquer are because I do not have to mix or clean anything up for 1 or 2 turnings - I am not doing alot of spraying or production work - Im not saying cleaning the spray guns are a big deal but I can move along faster rather then fiddle around with spray guns and cleaning with good results. Example: say I have 3-4 Finials - its faster for me and easier to use the Deft spray lacquer if i want a lacquer finish
    Most of my finishes now adays are done in Danish type oils (my own mixture as well as name brand) with Menzerna buffing/wax
    That being said I do have several spray guns - Kobalt HVLP - Paasche - Critter - Badger - The Critter puts out alot of spray in a oval type pattern and i find it least desirable of the list to spray turnings- Kobalt - works well with great control and adjustments but for a couple small projects I do not want to mess with the setup and cleanup - Paasche - great detail gun with alot of control and I do use it frequently (has 3 needles for different detail spray output) for dyes and small pojects - Badger is a inexpensive simple single action spray gun that hooks up to small glass jars and i can have several tinted lacquers mixed up or dyes etc - and change out quickly and easily - cleanup is just a mattter of submerging it into some lacquer thinner and holding the trigger open - it will clean it out and anthing sticking to it - Does it hurt the gun ? not so far and ive been using it for over 2yrs now - secondly its cheap enough to just buy another one but so far so good - it has a spring loaded spray adjustment on the tip and is simple to use - air pressure set at regulator/canister filter and run thru
    Pic 1 - wood sealer i use and it works well - EEE i use with my oil finishing
    Pic 2 - I use the Deft brush on to spray because i had it around and requires little cutting or none
    Pic 3 The Badger and spray bottle
    Pic 4 Cansiter filter/Regulator
    Attached Thumbnails Attached Thumbnails 20140425_153728.jpg   20140425_153815.jpg   20140425_154221.jpg   20140425_163800.jpg
  1. Acrylic spray finish on turnings
    Last Post: 04-26-2014, 11:53 AM
  2. Narrowing down how I finish my turnings - Question
    Last Post: 01-14-2012, 03:23 PM
  3. Laquer spray for turnings
    Last Post: 08-11-2011, 01:25 PM
  4. Finish/spray booth
    By Al killian in forum Finishing School
    Last Post: 12-17-2007, 07:15 PM
  5. Spray finish?
    Last Post: 10-24-2007, 10:46 PM
