Results 1 to 10 of 15
Thread: Dually Conversion ?
    Oct 2007
    Nova Scotia, 45N 64W
    1,245
    Dually Conversion ?
    As some know, we have an '05 F350 that had a hard previous life. It's single rear wheeled.
    Now it has a $2500 rear differential issue.
    So why not just replace the whole axle with a salvaged unit for a lot less? Then the discussion goes to "why not convert to a dually?" which would be beefier for trailering.
    Has anyone done this or heard of it? I'd be interested in some good impartial advice or direction (which is why I'm asking here, of course!).
    Any advice, as always, is very welcome. I've done some looking on the net, but got tired of threads that burned up time but weren't really very helpful.
    Thanks!
    5,172
    First question is what are you trailering? Second question, what is the plan for sheet metal fabrication for fenders for teh box? Third, question, are you having a problem trailering with what you have now? Then you also have different wheels and more tires.
    Obviously, an apples for apples exchange will be cheaper. Is there a compelling reason for going dually, beyond the wow/brag factor?
    Oct 2007
    1,245
    Well, the biggest load is a tri-axle 25' gooseneck flatbed Carol, that we occasionally load right up to the 30,000 gvw limit, in connection with a small business our son operates (with our involvement). We find the single rear wheels are barely up to that kind of loading and it really wears tires out fast. The other heavy load is a 12,000 lb dump trailer.
    As to the fenders, I understand there are aftermarket kits available. The box is somewhat dinged-up, so a flatdeck is another option (even more $). It needs new steel rims anyway, the aluminum alloy ones are toast. Issues aside, the truck is an awesome machine, like driving a locomotive.
    Money pit?
    Better to fix, sell and get a used dually with fewer issues?
    13,361
    Don't know much about the conversion, but as an owner of a 2000 F350 Diesel Dually, I can tell you the fenders appear to be pretty simple plastic 'add ons'.
    But for plastic addons, They seem to want a pretty penny. Hopefully you could find the used fenders at the same place you found the rear axle.
    You would also probably want to make sure the gear ratio's match, if it happens to be a 4wd. I know I had a selection of a few different ratios at the time I ordered my truck.
    5,172
    I think you are on to something there. Find a used dually and move on. Run the pencil against fixing the old one to sell or just selling as is. It isn't just dollars. It is also time and frustration. Down time as it is used for the business might also be an issue. Go shopping for another truck. Sounds like you need the dually. Not sure I would put money into a truck that barely gets the job done.
    Mar 2014
    Humid Gulf Coast
    542
    You could probably dual it pretty easy, but what about the springs. The springs will be for the old axel weight.
    Front springs too. If its just looks, the dual will probably work, but I don't think your tow capacity willgo up from just that.
    If you just get a low milage wrecking yard unit that matches the old one and replace the end seals, thats probably the cheapest way to go,
    but watch the gear ratio. If you have a 4.10 in the old one, a 3.10 in the new one will feel underpowered, and tow less.
    The parts for the 150 are the cheapest, when you to the larger ones, the parts cost a lot more.
    IMO, non-Ford aftermarket parts have a short lifespan, and cost close to FORD parts online.
    2nd cheapst way to go would be to rebuild the Axle yourself. It's a couple of days of dirty work.
    But when you are done, you have a new unit.
    Here is alink, maybe you can order a whole new Axle from FORD and just bolt it in:
    http://www.fordpartsgiant.com/catalo...uty-parts.html
    It's kind of fun to do the impossible
    13,361
    I do know that I've had some guys really want me to sell them mine, because of the 7.3 liter engine.
    You must have the 6.0 liter?
    North West Indiana
    6,098
    Well Peter, let me go against the majority here and side with your thoughts. You know the truck, the truck runs good, dependable, just could use a little help with the max gvw. And that is why duals were invented. I don't remember if this is a four wheel drive, if it isn't and is used off road (pastures, fields, yards, etc) duals are about as worthless as tits on a boar. In the winter they build up snow in between the wheels, they are a pain. But for load control, side sway is eliminated with proper tires and pressure. Great radial tires if going distances, but if it were here on my farm and pulling the trailer to the processor and salebarn, I would go with a great set of mud and snow tires for the great lugs and traction. Some of the dual rear ends may be geared lowered, lowering your fuel mileage so check for that. There has to be plenty of wrecked trucks that can donate a rear end and maybe even wheels and tires for your project. Now, caution, if it is a head on collision, tree, another vehicle, etc, sometimes the hits are so violent they ruin the transmission and transfer quite a punch through the driveshaft to the rear end. So look for a wreck that is from the side, front corner collision or something like that.
    Here in the midwest we have many outlets like this:
    http://www.pickuptrucksalvage.com/
    Here are a couple on ebay:
    http://www.ebay.com/bhp/ford-dually-bed
    My information concerning the wrecked components due to head on collisions, my dad owned and operated a service station and wrecker service for years and saw many vehicles that I wanted the trans out of and it was ruined because of a head on collision jamming the internal components even though it looked okay from the outside.
    Jon
    Oct 2007
    1,245
    It is a 6 litre, Brent. I've heard much lamenting among Ford guys about the discontinuation of the 7.3 though.
    Ours is a 4wd, so ratio matching is critical, or you have major issues of front and rear ends binding against each other.
    Thanks for all the other comments, especially Carol's. It is feeling like good money after bad to go to those extremes. Have to ponder this for a few days and get some prices figured out.
    Selling "as is" would be a big mark down I think, so more likely getting it up and running again in it's current configuration would be the thing. Transmission shop has it right now, apart, and already has a few hours into it to assess. Have to do right by him as he's a neighbour and friend.
    Thanks for now. I'll keep you posted.
    North West Indiana
    6,098
    Peter, did a quick google search for wrecked ford duallys for sale in canada. This came up:
    http://www.salvagetrucksauction.com/...RjM1MCBTVVBFUg
    Remember, many/MANY of the trucks the past few years in the US are coming out of flood areas. They are impossible to efficiently get running reliably again due to electronics. But for your needs, even if the truck sat in water, draining and flushing the rearend should be good to go. That is what we have done to trucks and tractors for years that got stuck and water logged.
    http://www.kijiji.ca/b-auto-body-par...ox/k0c317l9003
    Jon
  1. Is there a conversion kit
    By Chuck Ellis in forum New Tools
    Last Post: 07-06-2015, 01:07 AM
  2. The conversion process!
    Last Post: 08-03-2009, 09:24 AM
  3. Metalworking chuck conversion
    By curtis tolbert in forum Turning Tool Questions and Show & Tell
    Last Post: 06-22-2008, 12:26 PM
  4. Cement conversion........
    By Joe Tonich in forum Off Topic Discussion
    Last Post: 10-11-2007, 06:45 PM
  5. APC - American Power Conversion AttaBoy!!
    By Pete Simmons in forum Off Topic Discussion
    Last Post: 08-01-2007, 03:05 AM
