Results 1 to 9 of 9
Thread: A Shopmade Live Center Accessory
    I have the Oneway Live Center, it is a very good tool.
    It has a small center for most work, but it also has a threaded portion that you can put the larger center on or the reversible large bullnose center on, very useful, but, I find that one some items, like the Toothpick Dispensers I'm making the aluminum often leaves black marks on the wood.
    Here you can see the Oneway Live Center with a bolt inserted into the place you usually put the stop pin so you can unthread things, so I can install the live center on the headstock and it will turn, in this way I clean up the aluminum part, as it gets dinged up from use.
    I had some Delrin plastic on hand from a job and and ended up making this Delrin nose cone for the live center.
    I drilled it out with a 16.5mm bit and then threaded it with a 3/4"-10TPI tap, I think it is going to do the job nicely!
    11,831
    Clever adaptation from the Delrin, Stu. But, I am disturbed that Oneway uses aluminum for those parts. At the prices they charge for their stuff, one would think it would all be top grade steel.
    Aug 2008
    Reno, Nv
    3,632
    That's a big friggin bit! Should work well!
    The whole thing is top grade steel, the only parts that are not are the aluminium cones, but they are such so if you touch them with your tool you don't damage the tool.
    3,134
    S E Washington State
    3,777
    Old, Eddie, cracks me up. He doesn't always do things the way I would. I would not crank one of my fornster bits up against a piece of steel to hold a tap as I tapped something. I like my fornster bits! Seems to me that is not a good thing for that type of bit. And he always has these bandages on his fingers for some reason.
    Love to watch his stuff.
    "We the People ......"
    30,014
    Seconded. They use aluminum selectively for good reason.
    Jun 2007
    4,944
    Well, I did purchase the Oneway live center. As soon as I can get back in my shop I'll give it a spin (pun intended).
    I was going to turn a large "pointy" and a large "cone" to use in the live center I already have. However the Oneway looked too good to pass up. I'll find out in a couple weeks when I can find the lathe again.
    I enjoyed the show.
    Now You Enjoy,
    JimB
    VOTING MEMBER
    Oct 2007
    Schenectady, NY
    912
    Outstanding !!!
    Don Orr
    Woodturners make the World go ROUND
  1. Live Center Adaptor
    By Gord Rock in forum Turning Tool Questions and Show & Tell
    Last Post: 08-15-2009, 08:15 PM
  2. Live Center Question
    Last Post: 02-06-2009, 02:50 AM
  3. woodcraft pro center live tail
    By Dale Johnson in forum Old Ads
    Last Post: 10-14-2008, 04:37 PM
  4. Oneway Live Center..........*Got It!!*
    Last Post: 03-15-2008, 03:33 AM
  5. Nova Live Center System
    By Rick Levine in forum General Woodturning Q&A
    Last Post: 02-12-2007, 04:40 PM
