Results 1 to 10 of 18
Thread: Gee, that might leave a mark....
    So I was rough turning that piece of Shii wood, and as I'd not done a lot of green wood work in a while I sort of forgot that the spray of wood chips, especially from the EWT carbide tools, goes all over the place. I really need to put a guide rail and shower curtain in....
    Well my lathe took a beating, but it is used to it, lots of tannin in that wood as it turned the ways of my lathe black quickly. I turned around and saw a bunch of wood curlies on the top of my SawStop.... whoops.....
    this took about 15 minutes. There was a bunch of other stuff sitting on the saw top, so the pattern is varied, but man those wood chips did a number on my top..
    Better get right on that, I sprayed the whole thing down with WD40 and got out my old ROS and started to fix this. I did #120, #180, #220, #320, wiping it clean between grits, to make sure none of the old grit was present when I started the new grit.
    I used the WD40 on all the grits, as it helps in two way, IMHO, it shows me when to change the sanding disc, as the WD40 stops getting darker in color from sanding the metal and it slows down the sanding discs loading up.
    When I was all done I wiped it again with brake Kleen then I applied the CRC 3-36 rust inhibitor.
    It turned out just fine, but I'm going to make some sort of a cover for the top, I don't want to be doing this again anytime soon!
    13,450
    Ouch. Yeah my dad used to just keep a piece of 1/4" plywood or Luan on top of his when he wasn't using it, still looks shiny to this day. Said in his un-heated shop/garage that the condensation wouldn't be able to build up on it since the plywood would absorb the moisture.
    To a small child, the perfect granddad is unafraid of big dogs and fierce storms but absolutely terrified of the word boo. Robert Brault
    East Freeetown, Massachusetts
    3,020
    I do like the way you cleaned it up.
    I am going to try that next time I clean up
    12,258
    After many of these events I now use a healthy dose of pastewax and no more worries. Went through this winter without a rust patch. Also use this stuff http://www.leevalley.com/en/wood/pag...=1,43415,43440
    The stuff I use the CRC 3-36 is some of the best stuff on the market, IMHO, I used to use Johnsons floor wax paste, but this stuff is better, in my experience.
    My lathe ways are BLACK from the tannins in this wood, the SawStop was only rusty. I'm sure if it was not coated with the 3-36 stuff it would have been a LOT worse
    In a fairly recent Fine Woodworking article the compared all the various things on the market, Paste wax, and even the T-9 Boeshield did poorly on cast iron, the CRC 3-36 was best overall, and I really like it, I even use it on my bicycle stuff now.
    I did not have a full sheet of 1/4" plywood, so I had to join two bits together, I used some foil tape, then I used medium CA glue edge to edge, and then another layer of foil tape on the other side.
    I then put a lip on the underside all the way around, this works well, the cover is held in place by it's own weight and cannot slide around.
    Darren, thanks for passing along your dad's idea
    Oct 2007
    Nova Scotia, 45N 64W
    1,245
    Thanks Stu. You just put one more thing to my to-do list!
    I like your method though.
    Dec 2012
    Bedford, NH
    1,683
    I like to keep a protective cover on all my tools that tend to have things placed on them. i like to use large cardboard sheets that I remove from cardboard boxes that contain large items like TVs, etc. These also "breath" (so-to-speak) in that they don't trap moisture on the table surface. These, combined with Johnson's Paste Wax, work well. The cardboard sheets also work well as "lay-downs" whenever I need to crawl under the car, or whatever
    Thoughts entering one's mind need not exit one's mouth!
    As I age my memory fades .... and that's a load off my mind!
    "We Live In The Land Of The Free, Only Because Of The Brave"
    The problems we face today are there because the people who work for a living are outnumbered by those who vote for a living."
    Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
    Oct 2007
    1,245
    Stu, is that CRC 3-36 strictly a local product, or do you think it might be available here?
    Thanks
    PR
    Quote Originally Posted by Peter Rideout View Post
    Thanks
    PR
    Yes, CRC 3-36 is available over there, here its sold by a company called Kure.
    >> Here <<
    30,017
    Glad you got it cleaned up, Stu. Like Al, I use a large sheet of cardboard as my tablesaw cover. Between that and a layer of paste wax, I've had no rust issues. (Including the time I had a gallon of hydrochloric acid spill in the shop. That one caused every bit of exposed metal in my shop to rust from the fumes. My TS top was spared, because of the cardboard cover.)
  1. my mother always taught me, leave well enough alone
    By allen levine in forum Carpentry and Construction
    Last Post: 01-22-2013, 09:51 PM
  2. If it's not Dove season Leave me alone !
    Last Post: 11-08-2011, 04:00 AM
  3. Leave it to (Superman) Bradley
    By Jim C Bradley in forum Off Topic Discussion
    Last Post: 07-03-2011, 09:29 PM
  4. Leave it to a farmer
    Last Post: 08-07-2007, 12:48 PM
