Results 1 to 10 of 14
Thread: PVC DC ducts
    13,464
    PVC DC ducts
    For those using PVC for their DC pipes, what type are you using? Schedule 40 or the thinner stuff? I saw some of the thinner stuff over by the outdoor drainage supplies, just made me question which everyone was using.
    Jul 2007
    DSM, IA
    5,719
    I used the thinner stuff. The local habitat had 10' pipes for $5 so I took a chance and it works great.
    My Website
    13,464
    Cool, so it will slip over the plastic gates and connectors too?
    9,077
    6" ASTM-2729 with one bell end for all my stuff. Slides together air tight, is light and easy when changes are required. No problems at all. I'd do it again. Wish I had bought a few more extra sticks before the price jumped a few years back; I think I am down to two.
    Jul 2007
    DSM, IA
    5,719
    Yes it will, but I did have to add some tape to make it a bit more snug.
    My Website
    15,809
    Dunno, it's only one thickness easily available here in the 15cm stuff, I think it is the thicker stuff.
    17,475
    thinner stuff for the above the floor usage darren, and under ground i used scd 40 the plastic gates will fit in the fittings and may need some duct tape to fit snug but most fit fine use the metal duct tape to seal off regular duct tape doesnt hold up for the long haul.. i have some metal pipe here but your to far for shipping or delivery..unless you got someone over this way headed your way its free come get it.
    13,464
    Thanks all and thanks for the offer Larry, not quite sure what I need just yet.
    I've got the 2hp HF, so I can either pull the splitter off and go from the 5" inlet to some 6" pipe (what is available at the borg) , check with a local plumbing supply to see if 5" pvc is available, or just run two 4" runs, which may work fine for my layout. I've also seen where folks have removed the front plate with the 5" inlet on the DC and replace it with 1/2" mdf with a 6" connector added.
    So is dust collection anything like trying to pump water up a wall (think sump pump)? Is there any noticeable suction loss if the lift was to be 10' - 12' high and 30' - 50' in length?
    13,464
    BTW, going to try this stove pipe mod out...
    http://www.bt3central.com/showthread...=Stovepipe+mod
    He's using 5" stove pipe with two elbows to replace the flex line between the fan and separator.
    4,701
    Worth it - but imho better is to do what I did and lift the impeller up and turn it sideways and make it just a single straight shot into the fan and the bag assembly.
    5" PVC does exist but it rarer and I'm not sure if its available in the thinner/cheaper stuff. My tests with the HF unit and 6" flex weren't very encouraging, it was leaving a lot of material laying in the pipe which makes me think it probably doesn't have enough airspeed to keep the pipes clear at 6". Granted that was with flex not smoothwall so ymmv.
  1. DC - Rectangular/Oval Ducts?
    By Rob Bodenschatz in forum Carpentry and Construction
    Last Post: 03-10-2007, 04:40 AM
