Results 1 to 7 of 7
Thread: Squaring edge of toothing plane blade
    I have a wooden toothing plane that has an out of square cutting edge. I'd like to square it up and sharpen it. Is there anything I should do differently than when working with a regular plane blade?
    Jim
    17,470
    when you say toothing plane, do you mean a toothed iron for figured woods?
    Yes - I want to square the edge of the toothed blade in my toothing plane.
    5,319
    Quote Originally Posted by Jim Moore View Post
    Unless the blade is really out of square, I'd use the lateral adjustment, and just let it be canted a bit.
    Otherwise, you'll need to regrind the blade to square, then cut new teeth in it. It's not a hard job to do that, but does require some meticulous attention paid it.
    A three-cornered file will work well, but an even better choice would be a 'feather-edge' file like those sold for sharpening Japanese pull saws. It's probably going to take a couple hours to do it right. Sharpen the blade, same as with a conventional iron, then (being VERY CAREFUL not to cut yourself) cut in the new teeth. Wear gloves (preferably Kevlar) and keep bandaids handy.
    Catalunya
    4,632
    Square it up and sharpen like a normal blade but only on the bevel side. Once you are happy with it, remove the burr from the teeth by digging it on a piece of hard wood a couple of times with a hammer. Does that make sense? I do it that way and it is rather easy
    Best regards,
    Toni
    I'm uncertain what I would do in squaring the edge and resharpening that would cause me to need to recut new teeth...
    That makes sense. I was unsure if squaring the edge would affect the teeth - and your procedure addresses that concern. Thanks.
  1. How to plane/flatten large live edge boards bigger than 20"
    By Sam Keays in forum General Woodworking Q&A
    Last Post: 06-01-2015, 01:55 PM
  2. Edge rounding / cornering plane or tool
    By Dave Black in forum Neander Tool Questions and Show & Tell
    Last Post: 01-10-2012, 04:12 PM
  3. Saw blade marks on edge of wood
    By Dawson Mossman in forum General Woodworking Q&A
    Last Post: 12-07-2007, 11:27 AM
  4. New LV LH Edge Plane
    By Doug Shepard in forum Neander Woodworking Q&A
    Last Post: 09-04-2007, 11:31 PM
  5. New edge plane profiles from BCTW.......
    By Mark Rios in forum General Woodworking Q&A
    Last Post: 11-14-2006, 01:13 AM
