Results 1 to 10 of 14
Thread: Brad Nailer
    Jan 2012
    Bumpass, VA
    35
    Brad Nailer
    If it isn't one thing it's another. I think my Brad nailer bit the dust yesterday. Was working on a project for my church when after about a dozen or so shots with the brad nailer, there was a pop and then steady stream of air coming out of the exhaust port. I took it apart as best I could and didn't see anything obvious, after putting it back together still air out the exhaust. I think I paid about $50 for the nailer, probably 15 years ago, not sure if it's worth trying to fix.
    Any suggestions on a good one to replace it with?
    Thomasville, GA
    5,997
    I've had a Makita AF503 since about 2000 and it works like new. The only thing I had to replace is the cushioned nose piece.
    Bill Arnold
    17,472
    my recommendation is a senco model finish pro 25xp.. have had great service out of it for almost 20 yrs
    Feb 2012
    2,749
    I thought Brad Nailer used to be a shortstop for the Astros.
    Cheers,
    Roger
    Thomasville, GA
    5,997
    Yep, but he ran out of air and couldn't get to first base anymore!
    Bill Arnold
    May 2011
    So. Florida
    268
    Could be the cylinder is stuck open. A repair kit has "O" rings and repair parts to make it run like new. Give it a few drops of air tool oil before and after use each day.
    East Freeetown, Massachusetts
    3,020
    Have you been using oil EVERY time you use it - or daily?
    They NEED it.
    I work in Providence and the Bostich nailers are made a few towns over. Where I work, the Engineering Manager, My boss WAS engineering manager at Bostich. We also have a few engineers and machining people. THEY were making the ONLY oil less nailers I am aware of.
    You said you paid $50 for it - so I am guessing it is not Bostich.
    I have Porter Cable and oil them every time I use them. They work fine for what I do.
    Thomasville, GA
    5,997
    Quote Originally Posted by Leo Voisine View Post
    They NEED it. ...
    Up to a point, that's true. Getting too much oil in a tool like a nailer can cause finish problems down the road. I give mine a couple of drops of air tool oil occasionally, then fire a few brads into a piece of junk wood.
    Bill Arnold
    5,321
    ...Getting too much oil in a tool like a nailer can cause finish problems down the road. I give mine a couple of drops of air tool oil occasionally, then fire a few brads into a piece of junk wood.
    Yup! That's how I do it, too.
    4,552
    All that oil is good unless it is an oil-less gun then oil will ruin the o-rings-- and there ya have it.
    A Turn N Time
    Frog Pond Guitars
  1. Replies: 0
    Last Post: 04-16-2012, 01:43 PM
  2. Brad Nailer and Finish Nailer problems
    By Doug DeVore in forum General Woodworking Q&A
    Last Post: 11-09-2010, 04:23 PM
  3. Brad Nailer
    By Sal Cangialosi in forum New Tools
    Last Post: 02-01-2010, 04:08 PM
  4. Replies: 1
  5. Pin/Brad nailer
    By Porter Bassett in forum General Woodworking Q&A
    Last Post: 02-10-2008, 03:17 AM
