Results 1 to 2 of 2
Thread: A Question About Needle Files
    S E Washington State
    3,777
    I have a cheap set of HF needle files that I have about worn out. I want to replace them, because I do use them often. I'm wondering if the diamond files are better than the steel ones. Are they good for wood work or more for medal? I know nothing about them other than I use them a lot. Maybe the HF ones are good enough, but if there is an upgrade that is worth a little extra money I'd be willing to spring for it.
    "We the People ......"
    4,701
    I don't think the diamond ones would work all that great on wood, although I haven't tried them.. it seems like they'd be bad for clogging up with the more fiberous stuff.
    I have a set of italian made swiss cut needle files which I've only used lightly and have nothing to compare them to.. not super cheap and I mostly only use them for cleanup on details on carvings.
  1. EZ-Lap Diamond Needle Files - Poor Choice
    Last Post: 11-01-2015, 02:09 AM
  2. needle size?
    Last Post: 03-20-2015, 04:30 PM
  3. pdf files
    By Cynthia White in forum Site Questions and Test Posts
    Last Post: 03-14-2011, 12:46 PM
  4. Saws and files
    By Rob Keeble in forum Neander Tool Questions and Show & Tell
    Last Post: 03-12-2010, 09:33 PM
  5. HVLP needle size
    By Al killian in forum Finishing School
    Last Post: 03-29-2009, 10:04 PM
