Results 1 to 6 of 6
Thread: PC Bushings
    PC Bushings
    I have a DW614 router and PC bushings. The bushings are in a green box and made of brass, so I did not buy them at a flea market. The bushings work fine on my PC690. On the DW614 I can not tighten them even with pliers, they come loose in less than a minute of turning the router on. Short of buying a new set is there a solution?
    Thank You, DKT
    17,475
    you could replace the base on your dewalt router with a pat warner base that is made for PC bushings and would be dead center with the router spindle.. he make excellent bases.. or you could revamp a a old PC base for your dewalt router..
    Correction ! The router is a DW616, not that that makes a difference. On the bright side my wife solved the problem.
    Thanks, DKT
    17,475
    so how did your wise wife solve it?
    9,077
    Hat's off to your wife, whatever she did. I use these.
    Eureka, that is what my wife made for me. I haven't tried it out yet, but it should work.
    DKT
  1. Metric PC guide bushings
    Last Post: 08-17-2013, 07:45 PM
  2. Non Mandrel bushings?
    By Jim Burr in forum General Woodturning Q&A
    Last Post: 08-27-2010, 06:32 PM
  3. secret compartment keychain bushings
    Last Post: 01-08-2010, 01:52 AM
  4. Router Bushings????
    Last Post: 02-28-2009, 06:25 PM
