Results 1 to 10 of 11
Thread: 20" disc sander
    Central PA
    638
    20" disc sander
    I decided that I wanted a 20" disc sander... so I built one.Click image for larger version.
ID:	82990Click image for larger version.
ID:	82991Click image for larger version.
    5,323
    Looks great! Nice touches on the paint job, too.
    What's the horsepower on the motor?
    Awesome! Is the table cast iron or steel? Either way, that looks like a beast.
    5,174
    Wowza! Makes my little 10" shopmade disk sander look silly! What rpm does the motor turn? Got any idea what the rim speed is? Careful of the fingers. You could get a really awful manicure with that thing!
    Central PA
    638
    Thanks, I decided sometime back that if I was going to all the work of making tools I should make them look decent. The first thing I built was an 80" edge belt sander, it works fine but looks terrible.
    The disc sander has a 1725 rpm 1 HP motor, I was worried that it might not be big enough but I checked the amperage and its fine unless I am really abusing it. If theres decent paper in I see no instance where the motor would be overloaded. I made this from scrap, the only things I bought for it were the sanding disc and the aluminum for the backing disc. The rim speed is 106MPH if I remember my calculations correctly, so yes you could give speedy manicures if not careful.
    4,700
    Wow nice build! You don't mess around. The over arm switch is pretty sweet looking!
    10,604
    That's amazing. Nice job
    Jun 2007
    4,944
    I am impressed and JEALOUS.
    My dad had an 8 1/2" home made disk sander that I used a lot. I used it mainly to erase my mistakes---You know, to sand the end of the board down a bit to make it really the right length and square.
    I was really happy when I stepped up to a 12" sander. However, a 20" must be pretty much like a trip to Heaven. WOW!!!
    Enjoy (and think of me when you use it),
    Jim B
    VOTING MEMBER
    Central PA
    638
    Its steel, I was going to use an old atlas table saw top as the table for this but after I fitted it I realized that it was way to deep to comfortably use so I used a piece of 1/4" plate.
    East Freeetown, Massachusetts
    3,022
    Quote Originally Posted by Dave Black View Post
    I am with you there.
    Just because it's in the shop or it's a tool is no reason to stop short of finishing the job.
    Look GREAT.
  1. Built myself a 12" disc sander from a furnace motor and shop scraps. (video)
    By Art Mulder in forum Flatwork Project Showcase
    Last Post: 01-07-2015, 02:09 AM
  2. Disc Sander Sled Version 1
    Last Post: 04-25-2013, 08:32 PM
  3. Massive disc sander
    By Mohammad Madha in forum Off Topic Discussion
    Last Post: 06-04-2011, 05:49 AM
  4. Making a disc sander.
    By Bill Simpson in forum Jigs and Fixtures
    Last Post: 10-21-2008, 12:53 AM
  5. Rockwell/Delta 12"disc / 6" x 48" belt sander
    By Bryan Cowing in forum Old Iron
    Last Post: 10-17-2008, 02:37 PM
