Results 1 to 10 of 12
Thread: Shade Structure Build
    5,172
    As I posted earlier, I am building a shade structure that will become a gazebo once the house is built. For now, it will be a place to work out of the sun.
    Here is the drawing. There will be some tweaks along the way, but essentially it will be like this. Timber framing joinery is planned as this structure must be disassembled and then reassembled later.
    Once I had the lumber rack on the truck (sans paint - too windy), it was time to make a lumber run. I can tell you those 16' 4x4's are heavy!
Name:	1st lumber off the rack.jpg
    Timber framing joinery is mortise and tenon for the most part. Here is my test tenon on a scrap piece of 4x4. Haven't done any woodworking in a coon's age. Haven't done any timber framing in 20 years or more. This is fun.
Name:	Test Tenon.jpg
    Then the mortise. I bored 4 1" holes for the 2" square tenon.
Name:	Start Mortise.jpg
    And here is the test fit. The post will also be housed a 1/2" deep. I'll do that when the post fits. This was a test to make sure I had the tools I needed (being as most of my tools are in two zip codes.) and that my process was workable without being unnecessarily tedious. The joint is tight for now, but the wood is pretty green. I am happy that the concept has once again been proven and I have a process for each of the 4 vertical posts. Each fit will be specially trimmed until it slips together like a velvet glove.
Name:	Close enough.jpg
    Ahhhh... this was fun. Think I'll do some more tomorrow.
    AND, there was a reward for my efforts. The first raspberry of the summer.
Name:	1st raspberry.jpg
    13,360
    You certainly do not mess around. That's not just a shade structure, that will be an artistic wooden sculpture by the time you are done!
    30,014
    It may have been a long time since you've done any woodworking, but it sure looks like you still know what you're doing.
    Carol's Timberframing LLC. . Looking good Carol.
    Yorktown, Virginia
    5,013
    ...and not a router in sight!
    new york city burbs
    10,188
    how did you cut the tenon?(it looks like on the tablesaw but the marks can be from something else. Handsaw?)
    those 16 footers, make sure you pop a few advil before you start. back breakers for sure.
    Human Test Dummy
    5,172
    The shoulders of the tenon were cut on the SCMS against a stop to the proper depth. Then I used a hand saw to cut the cheeks, but today I am going to try my jigsaw. I got some blades that are long enough. It just occurred to me that I need to reverse the order. Cheeks first, then the shoulders. Otherwise the saw would not a reference surface. Thanks for asking the question, Allen. If I have to articulate the answer it means I have to put my brain in gear. Not a bad thing to do!
    13,440
    Looking good.
    Sent from my GT-N5110 using Tapatalk
    Catalunya
    4,632
    Looking good Carol, no sore muscles the day after?
    Best regards,
    Toni
    5,172
    First 'tool' in my box!
  1. repairing a lamp shade base
    Last Post: 07-19-2015, 02:56 PM
  2. Sysamore Lamp Shade an Base
    By Roy Millsaps in forum Lathe Project Showcase
    Last Post: 08-07-2014, 03:30 PM
  3. Day 2 of the Shade Structure
    By Carol Reed in forum Carpentry and Construction
    Last Post: 05-27-2014, 10:22 PM
  4. Turning a Lamp Shade - Who here showed this guy how to do it?
    By Pete Simmons in forum Lathe Project Showcase
    Last Post: 04-09-2013, 10:30 PM
  5. Oak floor lamp with stained glass shade -Build thread
    Last Post: 12-06-2012, 05:49 PM
